Newbie Question: Running NEC PG w/out neck boards
lostmandan
Posted: Mon Nov 10, 2008 6:25 pm    Post subject: Newbie Question: Running NEC PG w/out neck boards
For the newbie question of the day...
Do I run any risk of damage if I run an NEC PG without the neck boards installed (all cabling hanging, not shorted)?
This model has a passive neck board (no video amp on neck board).
Purpose - testing unknown deflection board without risking burnt tubes in case the deflection scan collapse circuit is not functioning for some reason. I don't really feel good about risking "minty" tubes.
Thanks in advance!
Posted: Mon Nov 10, 2008 6:31 pm    Post subject:
Nope, no problem at all.
lostmandan
Posted: Tue Nov 11, 2008 3:37 pm    Post subject:
Thanks Curt! Smile
Posted: Tue Nov 11, 2008 10:00 pm    Post subject:
The other way is to unplug the HV leads at the splitter. But stay away from the semi-exposed HV pins.
