kenvirginia
| Posted: Tue Nov 04, 2008 11:19 pm Post subject: Connecting HDFury EXT-HD box to D50 and having troubles |
All, I've finally gotten around to installing an EXT-HD (Older version)box to my D50 recently and it appears the blue light is not lighting up. I took the 5 BNC's straight into the EXT-HD and from the HDMI port into a HD Satellite rcvr. I get the wonderful HD signal with the red and green lights lit up however no blue. I can't believe the blue signal unique. Do I have to completely reconverge the system before the blue works? I also tried connecting a DVD to the component inputs and the blue signal does not work. I don't know if the next step in troubleshooting was correct or a proper test but I moved the blue BNC to the green output and the blue can lit up. The green cable did not work on the blue jack. Thoughts? This was a brand new box I bought in June and finally had time to connect and the blue port appears to be defective. I purchased the device through the links on this website. Ken
_________________ Ken
| Posted: Tue Nov 04, 2008 11:53 pm Post subject: Re: Connecting HDFury EXT-HD box to D50 and having troubles |
| kenvirginia wrote: | | All, I've finally gotten around to installing an HDfury EXT-HD box to my D50 recently and it appears the blue light is not lighting up. I took the 5 BNC's straight into the EXT-HD and from the HDMI port into a HD Satellite rcvr. I get the wonderful HD signal with the red and green lights lit up however no blue. I can't believe the blue signal unique. Do I have to completely reconverge the system before the blue works? I also tried connecting a DVD to the component inputs and the blue signal does not work. I don't know if the next step in troubleshooting was correct or a proper test but I moved the blue BNC to the green output and the blue can lit up. The green cable did not work on the blue jack. Thoughts? This was a brand new box I bought in June and finally had time to connect and the blue port appears to be defective. I purchased the device through the links on this website. Ken |
Hi Ken, you have your manufacture's confused. THe EXT-HD box is not an HDFury product. It's made by PJI-HD (Moome).
Contact Moome directly for any issues you are having. Maybe you did get a bad unit.
moome at curtpalme.com
kal Forum Administrator
