Barco 808s hot spots
Ile
Posted: Fri Oct 31, 2008 11:58 am    Post subject: Barco 808s hot spots
Played with thermographic camera yesterday. Here's few shot.
 Filesize:  10.39 KB
 Viewed:  10569 Time(s)
 Filesize:  12.62 KB
 Filesize:  16.09 KB
 Filesize:  10.53 KB
 Filesize:  13.49 KB
 Viewed:  10568 Time(s)
 Filesize:  12.95 KB
 Filesize:  12.53 KB
 Filesize:  10.67 KB
 Filesize:  14.27 KB
Ile
Posted: Fri Oct 31, 2008 12:03 pm    Post subject:
What the heck is this?
 Filesize:  11.4 KB
 Viewed:  10566 Time(s)
Ile
Posted: Fri Oct 31, 2008 12:05 pm    Post subject:
What car is this?
 Filesize:  11.42 KB
 Viewed:  10564 Time(s)
 Filesize:  13.96 KB
Posted: Fri Oct 31, 2008 12:10 pm    Post subject:
Ile, Seems that you should drop green drive a bit lower so that neckboards runs same temperature (second picture) Mr. Green
Car, lucky guess: Ford Cortina?
DVDO VP-50
New hobby, Rally
Ile
Posted: Fri Oct 31, 2008 12:16 pm    Post subject:
I was also wondering that.
No, it's not Cortina.
Posted: Fri Oct 31, 2008 12:56 pm    Post subject:
Car went wrong, but is that another mystery item: Tivoli Audio radio?
DVDO VP-50
New hobby, Rally
Ile
Posted: Fri Oct 31, 2008 12:59 pm    Post subject:
Yes, it's model one.
Posted: Fri Oct 31, 2008 3:35 pm    Post subject:
A tube radio?
<edit> I should read the whole thread before quoting..Very Happy
Now you guys can see why I frown on most fan mods. I consider the Barco projectors to run cool overall compared to say NECs. Look at the temperature chart of the hotspots of the Barco. Ouch!
Posted: Tue Nov 03, 2009 7:50 pm    Post subject:
it all depends on how you look at it. For instance, Fan mod's = more repair work for Curt Wink
Posted: Tue Nov 03, 2009 8:13 pm    Post subject:
True, but usually more of a 'throw it out, it's toasted' type of parts sale. I'll take it, but I'd rather do an actual repair. Board swapping isn't a challenge.
TheVerge
Posted: Tue Nov 03, 2009 10:36 pm    Post subject:
Predator vision... i want one of those
mc86
Posted: Tue Jun 19, 2012 11:26 pm    Post subject:
Boy, I dunno, fan mods seem all the more needed to me IF temp is detrimental to a given part. That is, I know electrolytic caps do have longer lifetimes with cooler temps...but I'm not sure on the super-hot MOSFETs. 80decC components could use some mini, additional direct cooling - some of those tiny 3cm-ish fans located near components couldn't hurt and are nearly silent and easy to mount with sheet metal.
Matt
Posted: Wed Jun 20, 2012 1:07 am    Post subject:
How hot is hot? What temp does red represent in the thermal images of the 808??
Ile
Posted: Wed Jun 20, 2012 6:39 am    Post subject:
Camera have automatic scaling, so scale vary from picture to picture. Celcius scale is printed at every picture, so for example Hsift board picture have around 125 Celcius degree (dark red) at hottest area.
