bbfarmht
Joined: 27 May 2006 Posts: 1273 Location: Where the Mississippi runs east to west!!
| Posted: Fri Oct 31, 2008 1:11 am Post subject: folded horn speakers |
Who has experience with this type of speaker?
Would this not be an ideal speaker for ht? I've never heard these before. There is quiet a bit of info, but mostly from small custom builders.
_________________ Adam
Benjamin Franklin
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Fri Oct 31, 2008 1:26 am Post subject: Re: folded horn speakers |
| bbfarmht wrote: | Who has experience with this type of speaker?
Would this not be an ideal speaker for ht? I've never heard these before. There is quiet a bit of info, but mostly from small custom builders. |
They are great! Very, very efficient. 20 watts would probably bring the walls down. If your good with wood and stuff, get the plans and make your own. They are BIG!
Back in the old days, these were great to be driven with tube amps like Dynaco.
See Klipschorn or look-up stuff on folded horn speakers.
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
mike calcott
| Posted: Fri Oct 31, 2008 1:30 am Post subject: |
Klips corner horns will make your ears bleed
_________________ Old dog learning new tricks
kal Forum Administrator
bbfarmht
| Posted: Fri Oct 31, 2008 1:49 am Post subject: |
So, they would be great if you were to use a tube amp?
Really what I am looking for is a speaker that has a very nice mid-range.
I listened to some B&Ws and I liked the way they handled the mid-range, and that the highs were not harsh or over powering.
Benjamin Franklin
wallace123456
| Posted: Fri Oct 31, 2008 2:03 am Post subject: |
| bbfarmht wrote: | So, they would be great if you were to use a tube amp?
I listened to some B&Ws and I liked the way they handled the mid-range, and that the highs were not harsh or over powering. |
The tube amp thing is a whole debate in itself. Me? I think tube amps sounded better with high efficient speakers such as klipsch and altec-lansing. But then again, tube amps were pretty much cheap and the main course 35 years ago.
Klipsch (folded horn speakers in general) has tons of mid-range. Sometimes, too much. IMO, you would need a decent equalizer to be able to tame the horns to your liking.
Room sound treatments come into play bigtime with these type speakers.
I agree with Kal; give them a listen first. Your ears hear the best; not mine.
wallace
bbfarmht
| Posted: Fri Oct 31, 2008 2:17 am Post subject: |
I've seen the plans and also the complete speakers.
The plans however, seem to just be for the subs.
Not sure where I could go to find someone with some to hear them. So I was thinking that I might try to make folded horn sub to get a feel for them.
Benjamin Franklin
wallace123456
| Posted: Fri Oct 31, 2008 2:28 am Post subject: |
Folded horn speakers tend to be 2-way. 1 horn (deep throat) and 1 big sub (15" or larger). The magnet on the sub driver is not that big by todays sub driver standards.
wallace
jask
deronmoped
| Posted: Wed Nov 19, 2008 4:52 pm Post subject: |
I have some folded 18" Cerwin Vega's, they kick butt using them as subs. I got to listen to some Klipschorn's a long time ago, what I remember is that they had incredible bass and they were huge.
Deron.
Axatax
| Posted: Mon Nov 24, 2008 8:47 pm Post subject: |
| Quote: | | Klipsch (folded horn speakers in general) has tons of mid-range. Sometimes, too much. IMO, you would need a decent equalizer to be able to tame the horns to your liking. |
Does Klipsch actually make any speakers with a folded mid-range horn? I thought only the woofers were folded?
enigma
| Posted: Wed Nov 26, 2008 11:49 pm Post subject: |
Hey guys,
Horn speakers are a whole new can of worms.
There are front loaded & rear loaded designs, Klipsch horns for example are front loaded. Front loaded is where the horn extends from the front of the driver & you guessed it, rear loaded is where the horn extends from the rear.
Valve amps are perfect for horns for two main reasons, horns are efficent and only require low wattage, valve amps are low wattage and operate at their optimum with just a few watts.
If you run a solid state amp at a few watts, the sound can be terrible because it is not performing within its optimum range.
Klipsch are 3 way designs, many horns with single drivers are full range designs and sound sweet. Some designs can benefit from the use of subwoofers, many are fine without them. It really comes down to taste and design.
It is best to get to know what they are and pick a design that suites your needs. Stick with modern designs as they are better. Klipsch still manufacture their horn speakers.
Here is some info; http://jasondiyaudio.blogspot.com/2008/01/diy-back-loaded-horn-speakers-blh_15.html
also google Hedlund or Carfrae or Kleinhorn for some great full range, back loaded folded horn designs using either lowther or fostex drivers. The Carfrae has a subwoofer as part of the design.
All the best with building them.
