jarseneau
| Posted: Wed Oct 29, 2008 10:32 pm Post subject: NEC PG6 Brightness acting 'shifty' |
Has anybody else seen a problem where the picture gets noticably brighter (as in blacks are grey) with the image shift setting close to midrange (0) and gets much darker by moving the image to -35. The problem is that the picture is too bright when centered properly but has better blacks when shifted and dark. I could re-do the G2 setup to get the blacks better with the picture centered but don't want to 'fight' with whatever is making the brightness change with position.
When I shift to the right, the raster starts to fold over the non image area and then bands show up in the foldover.
Any idears??
_________________ Jerry
| Posted: Wed Oct 29, 2008 10:37 pm Post subject: |
That is normal. Most sets will dim out when you shift the H phase too far to one side. The correct position is when the image is centered. If that's too bright, then you have G2/video drive/input signal issues.
Cheers!
Curt
jarseneau
| Posted: Fri Oct 31, 2008 1:17 am Post subject: |
Thanks Curt! I'll go with that then.
