djphatic
| Posted: Wed Oct 29, 2008 6:47 pm Post subject: Calibrate PC with HCFR running on same machine? |
Hi
I have just following the dummies guide to greyscale using my PS3 as the source with DVE HD Basics blu-ray. I also have my HTPC connected to the same screen I have been calibrating.
I would like to run a greyscale test with HTPC as the source and my HTPC running HCFR, is this possible or do I require another PC running HCFR?
Mark
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Mon Dec 01, 2008 6:47 pm Post subject: Re: Calibrate PC with HCFR running on same machine? |
| djphatic wrote: | I would like to run a greyscale test with HTPC as the source and my HTPC running HCFR, is this possible or do I require another PC running HCFR?
Mark,
Same HTPC that is exactly how I do it. The probe is plugged into my HTPC and runs closed loop. Push one button/icon and HCFR will do full grey scale, primary, and secondary color measurements automatically. Just sit back and wait.
I prefer this to running a separate source CD because I can make more adjustments and sample the results much faster. So I get more iterations per hour.
| Posted: Mon Dec 01, 2008 7:26 pm Post subject: |
I've been thinking about this, too... You can do it that way, but you'd have to make sure the HTPC was "neutral" - i.e. same gamma, color, etc. as the other sources - or else you'd be calibrating the HTPC only and everything else would be wrong... Right?
AFryia
| Posted: Mon Dec 01, 2008 8:45 pm Post subject: |
| ecrabb wrote: | | you'd have to make sure the HTPC was "neutral" - i.e. same gamma, color, etc. as the other sources - or else you'd be calibrating the HTPC only and everything else would be wrong... Right? |
SC true. The same can be said for all sources.
In my case I run the HTPC through input 'B' and the PJ loads a custom COLOR/TEMP setting. My HD runs through input 'A' and the PJ loads the default 6500K color setting. That covers 99% of my viewing.
