| Posted: Thu Oct 23, 2008 10:47 am Post subject: Bath & Pantry in Basement |
I am at the point where the electrical rough in is complete and the drywallers are on hold waiting for the [forgotten] plumbing rough in. While the full bath in the basement is pre-stubbed with pit for the ejector pump, and the electrical for the bath and clothes washer ejector pumps pre-wired, I need a plumber ASAP.
I figured this would be a great time (in my life) to attempt to find someone experienced with Pex tubing instead of the traditional copper. Also, I wonder about the use of point-of-use tankless hot water heaters. Both the bath and the pantry [on steroids] are adjacent to one another, but unfortunately I know of not a single plumber in this region that has used Pex.
What did everyone else use? Copper, PVC, buckets?
tri_joel
Joined: 03 Jul 2007 Posts: 646 Location: Northern Virginia
| Posted: Thu Oct 23, 2008 1:31 pm Post subject: |
I used copper for all of my domestic water supply. I built a house with reverse osmosis water filtration, we had to rip out all of the copper pipe and install PEX because the filtered water would pick up the taste of the copper. If you are going to use PEX do not buy the box store stuff, spend the very little extra money and buy from a plumbing store. I forget the specifics, but you want the stuff that is rated for in-concrete use even if you are not using it in concrete. The non-concrete stuff will not last as long.
I'm installing PEX for radiant floor heat in my house. It is cheap and easy to install, the crimping tool and fittings are a bit pricey. An interesting note about PEX is that Zurn is phasing out their PEX products. I have no idea why.
_________________ www.vawinesnob.com
| Posted: Thu Oct 23, 2008 3:35 pm Post subject: |
Wan, I think you'll want to stick with copper if the rest of the house is plumbed that way. You don't want some of one and some of another - it'll look cheesy to buyers down the road - as if the basement was finished later and "tacked on". (It was, but you don't want to look that way, if possible).
Plus, I would think the PEX would probably cost a little more by the time you figured in your lack of finding somebody (no competitive bids?). You don't plumb the same with PEX as you do with copper. You can do branches with tees and reducers with copper, but with PEX, the runs for each faucet, toilet, etc. are all separate. Each run goes back to a manifold. Just the manifold would probably cost you a couple hundred bucks.
FYI.
PS - I have the ViegaPEX tubing in my house and the MANABLOC distribution manifold:
http://www.viega.net/4741.htm
The manifold isn't quite as expensive as I remember, but the tools are expensive. I'll likely hire somebody to do my basement bat and bar.
| Posted: Thu Oct 23, 2008 4:41 pm Post subject: |
PEX is getting big here in phila. 1. Because of the rising price of metals. 2. because people were breaking into construction sites and STEALING copper pipes right out of the walls!
I like it. It's faster and safe.
_________________ Follow my blog
JustGreg
| Posted: Thu Oct 23, 2008 5:19 pm Post subject: |
| emdawgz1 wrote: | PEX is getting big here in phila. 1. Because of the rising price of metals. 2. because people were breaking into construction sites and STEALING copper pipes right out of the walls!
I like it. It's faster and safe. |
Good snag there John. I was going to talk about the current cost of copper too. Although it's trading lower (what isn't) the lower price hasn't reached the retail level yet...it's still very pricey IMO. (developing nations like China and India are scarfing it all up)
The PEX can be done by anybody who's even mildly handy whereas sweating copper takes some practice. If you can screw the cap on and off a jar of pickles, you can install PEX.
My house, although built in the late 70's, is almost all PVC. The only copper used was for the added on later basement full bath (outside my HT) for the terlet, shower, and for the solar panel tanks and such that are in the mechanicals room.
Next year, if all goes well I'm going to extend/enlarge our livingroom width by 7 feet. I'll be removing the covered deck and that wall and preparing the ground as opposed to digging and pouring a foundation. I plan to steal from the solar panels for radiant heating. I won't have to cut the existing foundation to fit ductwork through that way. Piece of cake right?
I say go for it yourself WM. You may only need a plumber to create a tie-in for hot and cold water and you'll save a bucketload of money.
EDIT: Just found this. Funny video. Good speeeling!
http://www.youtube.com/watch?v=ABX40lp5Vb0
_________________ Greg
jask
| Posted: Fri Oct 24, 2008 7:35 pm Post subject: |
I use copper when I have a choice but PEX is a good product, it can be easily added to or combined with copper and can be installed trunk and branch,-just like copper, or home run,-just like copper. you can buy all of the fittings adapters and transition parts at any good plumbing shop or even home depot. Ring crimpers are available at most tool rental shops, including home depot. Read up on installation and crimping before you start, almost every leak I have seen with PEX has been from poor crimps. I like to add shut offs at the start of a new branch when I can ( inline ball valves) and if any problems or leaks show up, the whole house does not need to be drained down.
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Mon Nov 10, 2008 3:07 pm Post subject: |
| tri_joel wrote: | I used copper for all of my domestic water supply. I built a house with reverse osmosis water filtration, we had to rip out all of the copper pipe and install PEX because the filtered water would pick up the taste of the copper. If you are going to use PEX do not buy the box store stuff, spend the very little extra money and buy from a plumbing store. I forget the specifics, but you want the stuff that is rated for in-concrete use even if you are not using it in concrete. The non-concrete stuff will not last as long.
I'm installing PEX for radiant floor heat in my house. It is cheap and easy to install, the crimping tool and fittings are a bit pricey. An interesting note about PEX is that Zurn is phasing out their PEX products. I have no idea why. |
Umm, a RO system with copper is not a good idea.
Unless you control the conductivity it will remove the copper ions from the pipe. It will also have the tendency to become very corrosive in stagent area of the pipe run.
However copper is the best idea for a regular filter system due to the fact that bacteria can not live on copper.
_________________ Engineer by Day
Photographer by Night
My Portfolio
| Posted: Tue Nov 11, 2008 11:09 am Post subject: |
I'll be talking about this with the plumber today. Yesterday afternoon he stopped buy to run the PVC drains, and install the ejector pit and pump. This morning I am picking up a 30"x60" shower base. Wife and decided the house already has three combination shower-tubs. We are going with the Kohler Devonshire installed in the ceiling.
At this time, I am looking for quotes from local providers on stainless steel shower surrounds and shower ceiling cap. Yes, this is going to be what the guys on FHB are calling the Auschwitz shower. The alternative in my application for a low-maintenance surround surface was tempered glass, but I think the porous nature of glass would actually not be good. Besides, makes cleaning up homicidal accidents easy if I install a garbage disposal.
paw
| Posted: Wed Nov 12, 2008 2:33 am Post subject: |
| WanMan wrote: | I'll be talking about this with the plumber today. Yesterday afternoon he stopped buy to run the PVC drains, and install the ejector pit and pump. This morning I am picking up a 30"x60" shower base. Wife and decided the house already has three combination shower-tubs. We are going with the Kohler Devonshire installed in the ceiling.
At this time, I am looking for quotes from local providers on stainless steel shower surrounds and shower ceiling cap. Yes, this is going to be what the guys on FHB are calling the Auschwitz shower. The alternative in my application for a low-maintenance surround surface was tempered glass, but I think the porous nature of glass would actually not be good. Besides, makes cleaning up homicidal accidents easy if I install a garbage disposal.  |
I've seen solid surface materials used as low maintenace surround surfaces. No grout lines.
_________________ Aubrey
| Posted: Wed Nov 12, 2008 9:47 am Post subject: |
Solid surfaces tend to lean around $35-50 per square-foot. I got a quote for cultured marble and it was about $14-15/SqFt.
After slapping ourselves in the face, we had to remind ourselves that this is a basement bathroom, AND if money is to be spent on a nice shower then spend it on the master bathroom.
So, come next Spring we'll re-do the master bathroom and for now just use some acrylic faux tile surrounds and leave it at that.
paw
| Posted: Thu Nov 13, 2008 4:51 pm Post subject: |
Why the faux tile? Then you just have to scrub the scum out of the fake grout lines. I'd go for the smooth acrylic. OH! Acrylic is a pain to clean. Try waxing or a coat of Klasse (my recommendation) on it. Don't wax the floor of the surround! Unless your mother in law is coming for a visit.
| Posted: Thu Nov 13, 2008 5:59 pm Post subject: |
I think the only time this tubless shower will be used is when some party animal needs to be watered down (laundered).
