johnsmith808
| Posted: Thu Oct 23, 2008 7:45 am Post subject: Marquee 8000 needs anamorphic mod to display 16x9? |
I was wondering what this anamorphic squeeze mod was all about. Apparently without doing this mod, my Marquee 8000 will not be able to have a 16x9 raster? Is this hard to do?
ralpharch
| Posted: Thu Oct 23, 2008 1:37 pm Post subject: |
From a low tech guy with an 81110 Marquee who has not done the mod in the 3 or so years of owning the pj; its not something critical to do right away.
I don't use full vertical size adjustment (down to 0) - I end up around 6-10% and the 16:9 looks fine for me.
I realize I am driving circuits harder than needed because of this; and perhaps the mod is not that difficult; but getting your projector working and set up in anamorphic (perhaps just a little short of full 16:9 squeeze - could depend on specific pj) does not require the mod.
johnsmith808
| Posted: Fri Oct 24, 2008 12:09 am Post subject: |
Okay, so I guess I'll see if my pj is able to do the right raster size once it's working. I guess then I'll know if I need to do the mod.
By the way Athanasios, is this the right part you were referring to?
"that mod is commonly known as "vertical squeeze mod" it decreases the vertical size for 16:9 operation. I think you're right that the circuit was probably designed more for computer presentation.
The mod requires the replacement of 3 resistors on the vertical board (R704, R804 and R904). These resistors are 30K ohm, they should be replaced with 56K ohm resistors, and it's best to use metal film resistors @ 1 to 5% tolerance. I use 1% 1/4 watt from Digikey.com:
Part# 56.2KXB"
Thanks.
johnsmith808
| Posted: Fri Oct 24, 2008 1:47 am Post subject: |
I am sorry but I have no experience in modding. What exactly will I need to do this? Do you think it's doable for a newbie?
Thanks.
| Posted: Fri Oct 24, 2008 3:11 am Post subject: |
Well if you can do some basic soldering its not hard , but if you have some old electronic parts you can pratice removing resisitors from and then putting them back on id do that first, its how i got started two years ago. Then when you feel comfortable you can do it to your own boards on the PJ. But I warn you, you could become adicted! I have .
A basice soldering iron of like 15-30 watt type and some soldering wire and some desoldering braid to suck up the solder off the board. do a search for soldering tecniques on the web, lot of info.
| Posted: Fri Oct 24, 2008 3:14 am Post subject: |
Desoldering braid is a MUST. It turns next-to-impossible into dead easy. Don't even try without it.
| Posted: Fri Oct 24, 2008 5:00 am Post subject: |
| perisoft wrote: | | Desoldering braid is a MUST. It turns next-to-impossible into dead easy. Don't even try without it. |
I must have bought some cheap braid. I ended up with a solder sucker I have had better luck with it than the braid.
johnsmith808
| Posted: Fri Oct 24, 2008 8:25 am Post subject: |
Can you get all of that stuff from Radio Shack? I guess the replacement resister/parts need to be ordered online though.
