| Posted: Fri Sep 26, 2008 12:23 am Post subject: Now the G90 is dead! |
Been having this shaking problem http://www.avsforum.com/avs-vb/showthread.php?t=1059436.
I was watching the G90 today and suddenly seem to have lost high voltage. Picture was fine then became blurry, then dimmed out, all in less than 10 seconds. Now I have no raster, no OSD's, and no crackling sound when I start the projector. Also NO ERROR codes. Projector starts and runs fine except no image
I'll start working backwards tonight or tomorrow, but if anyone has any wisdom on loss of high voltage with no error codes I'd be happy to listen.
Also, I just finished John's fan mod to the front fan right before this happened. Seems a little odd, but hey stranger things have happened.
| Posted: Fri Sep 26, 2008 1:00 am Post subject: |
PA board maybe, the one in the front under the green lens?
I do have a test chassis here, plus two more G90s coming in. Let me know if you can't get it going.
kal Forum Administrator
| Posted: Fri Sep 26, 2008 2:18 am Post subject: |
| kal wrote: | Get it fixed Craig! You need to keep testing Moome's IFB-FULLHD HDMI card!
P.S. FWIW, I don't trust those SilenX fans. They don't move anywhere near as much air as they say they do. I mod'ed my Barco Cine 8 with 3 of them and my measured temps went through the roof so I put the stock ones back. |
Yeah, I am definitely going back to stock fans. I could tell these new ones weren't moving as much air just by putting my hand in front of them.
| Posted: Fri Sep 26, 2008 2:22 am Post subject: |
| Curt Palme wrote: | PA board maybe, the one in the front under the green lens?
I do have a test chassis here, plus two more G90s coming in. Let me know if you can't get it going. |
I think I might take you up on this Curt...
I may want to borrow the PA and PD and the G boards in back. I just had the PA and PD boards from Terry here two weeks ago and sent them back to him after they didn't help my shaking problem. However, I am hoping that the shaking and the loss of high voltage are related issues, but I don't think so...
I think the SilentX fan ruined my PA or PD, and that I still may have a faulty G board. I'd like to get both problems resolved with as little back and forth shipping as possible. I'll put a scope on the PA tomorrow and see what I see. It will probably be extremely helpful to have a working PA here to help narrow down to component level repair. I wish I had a spare working chassis.
| Posted: Fri Sep 26, 2008 2:24 am Post subject: |
Kal |
Yeah, I haven't told Moome about this dilemma yet Bad timing!
| Posted: Fri Sep 26, 2008 3:24 am Post subject: |
I did a test on my marquee with fans where I taped a placed a piece of paper over the focus and HDM exhaust holes with only one end taped down and measured the deflection of the paper, then i put in the new fans and measuer how much they moved the paper up, if it was less i tried a different fan. I ended up with a thermaltake fan but added resistors to slow it down till it deflected the paper the same as the stock fans, kinda how Tim did the belly fans .
I hope you figure it out Craig.
kschmit2
| Posted: Fri Sep 26, 2008 7:27 am Post subject: |
Athanasios:
PC fans are meant to operate 8 hours/day over a course of 3 years.
Not one of them is spec'd for 24/7 operation, and definitely not for 50k-70k hours like the fans used in commercial grade CRT front projectors.
I would never trust PC fans for that very reason.
richardc
| Posted: Fri Sep 26, 2008 9:25 am Post subject: |
I did the fan mod on my newly aquired G90 and I also have gone back to the standard fans, it is quiet with the mod but it just does not push enough air.
I live in Oz and the temperature here can go to 40 degrees and down to 0 degrees C.
Also when we see Mike Parkers mod 1080P @ 72Hz this will really warm things up.
Just my thoughts
Richard
| Posted: Fri Sep 26, 2008 10:27 am Post subject: |
| kschmit2 wrote: | Athanasios:
I would never trust PC fans for that very reason. |
You should consider fans from a server. Some are quiet (you will have to test to find quiet fans) and all are designed to run 24/7 forever and they move serious amounts of air.
Chuchuf
| Posted: Fri Sep 26, 2008 2:07 pm Post subject: |
I to went back to the stock fans and built a hush box.
Craig, what boards do you need??
Terry
| Posted: Fri Sep 26, 2008 2:38 pm Post subject: |
| Chuchuf wrote: | I to went back to the stock fans and built a hush box.
Terry |
Terry,
I think I may want to borrow the PA and PD again (ARG!!!) as I think that's probably what's wrong now. I think the SilentX fan overheated the PA probably. I'd also like to borrow a set of G boards from the back of the set to see if a power supply issue is causing the shaking.
I will be getting the oscope out shortly to make a preliminary diagnostic. I'll know more this afternoon.
FWIW I would rather get the boards from you than Curt only because then I don't have to deal with customs and the shipping will be cheaper. However, it sounds like Curt may have several spare chassis shortly so it may be a little easier for him to part with boards...
I really appreciate both you guys' offers
| Posted: Fri Sep 26, 2008 2:50 pm Post subject: |
Not entirely true. I remember cleaning out a Dell desktop a few years ago that had the same NMB fans that my Barco has.
| Posted: Fri Sep 26, 2008 5:25 pm Post subject: |
All right, I have an update and could use some help form you guys...
I have been trouble shooting the PA board.
Q602 is toast, D608 is toast, and all six fuseable links are blown (R614, 615, 616, 617, 618, 619). Q601 is a JFET and is "Sony" part number 2SK2349-CB. I have found them online, but at over $175 each Page 10-111 of the service manual has the diagram for the transistor and page 8-28 lists the part number. I am not good with JFET transistors (or substitutions in general) so if someone can help me maybe come up with a substitute for the Q602 I would really appreciate a cheaper alternative. PLEASE I HOPE because that's the most freaking expensive transistor I have ever seen.
D608 is part number RD20ESB2. I am having trouble finding info on this diode as well but I think it might be a 2.0 volt, 0.4 watt, zener; can someone confirm this for me. If that's all it is, I'll definitely just get the diode from Digi-Key along with other parts.
JohnHWman
Joined: 15 May 2007 Posts: 215 Location: France - Grenoble
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
| Posted: Fri Sep 26, 2008 7:34 pm Post subject: |
Craig,
I'm sorry for your troubles on PA board
Did you pay attention to the wiring of the PA boards incoming leads/connectors when you re-assembled all the things ? I'm specially thinking about big black HV connectors on the far left/right locations on the PA board. They are named CN89/CN90. Those two female connectors are 875Vpp HV power and must be well secured inside their male on-PA-board parts (you must hear a dual 'click' when they are properly inserted).
For Q602 : This is not a J-FET but rather a Power N-MOSFET for HV DC/DC switching PSU. It is not a Sony part but a Sanyo part. See: http://www.eu.sc-sanyo.com/ProductInfo/Transistor/MOSFETs/Datasheet/2SK2349.pdf
There should be equivalent part available on the market. Most important parameters are VDSS, VGSS, IDP, PD, VGS(off) and RDS (on) and the pinout should be standard for this package (2131-TO-3JML).
Beware that because Q600/Q601 and Q602 are acting in parallel with same phase, the three parts must share the same transcient specifications (so, same part numbers...)
Ending, if one part has burned, check its relevant PRE-DRIVE stage (Q507/Q508) health !
Hope this helps
John
P.S. FYI, I have three G90 (one is mine) in France that were modded with the SilenX fans that are running for years now without any issue
_________________ Home theater enthusiast for over 20 years !
My dedicated HT room !
| Posted: Fri Sep 26, 2008 8:24 pm Post subject: |
| Quote: |
Did you pay attention to the wiring of the PA boards incoming leads/connectors when you re-assembled all the things ? I'm specially thinking about big black HV connectors on the far left/right locations on the PA board. They are named CN89/CN90. Those two female connectors are 875Vpp HV power and must be well secured inside their male on-PA-board parts (you must hear a dual 'click' when they are properly inserted). |
Naturally, they were seated well, of that I am sure.
| Quote: | For Q602 : This is not a J-FET but rather a Power N-MOSFET for HV DC/DC switching PSU. It is not a Sony part but a Sanyo part. See: http://www.eu.sc-sanyo.com/ProductIn...et/2SK2349.pdf
There should be equivalent part available on the market. Most important parameters are VDSS, VGSS, IDP, PD, VGS(off) and RDS (on) and the pinout should be standard for this package (2131-TO-3JML). |
THANK YOU!
| Quote: | | Beware that because Q600/Q601 and Q602 are acting in parallel with same phase, |
Excellent advice John, I will check them now.
| Quote: | | P.S. FYI, I have three G90 (one is mine) in France that were modded with the SilenX fans that are running for years now without any issue. |
Yeah, I know. But hat being said, the transistor that failed was the furthest from the fan so... I don't know, I think I am going back to stock fans :p
| Posted: Fri Sep 26, 2008 8:46 pm Post subject: |
Also John... I think at this point you MUST be the guru of component level repair on the G90's and I am very thankful to have your assistance.
Let's just hope I didn't miss anything while looking over the PA.
| Posted: Fri Sep 26, 2008 9:55 pm Post subject: |
| richardc wrote: | craigr
Just my thoughts
Richard |
You know... I was running 800x1920 @ 72 Hz when this happened. John runs at 48Hz so this possibly keeps his projector cooler
dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
Criag,
If it gets to a point and your G90 is not ceiling mounted, you could always bring that thing down to the "LOU" and trouble shoot by board swapping!
Doc
