Best resolution for DWIN HD500 and Lumagen HDQ
beckma
Posted: Tue Sep 23, 2008 10:34 am    Post subject: Best resolution for DWIN HD500 and Lumagen HDQ
Hello,
I'm using a Dwin HD 500 together with a Lumagen HDQ and the new Moome HDMI->RGB converter.
On my old Sony D50 I used Pal progressive (576p) direct from my Denon 3930 via YUV.
For HD I used 1080i also via YUV. Everything looked perfekt.
If I enter 576p in the Lumagen the Dwin will not sync.
Can anybody tell me the full timing settings for PAL.
If I enter 540p and 1080i I can clearly see the scanlines.
If I enter 720p everythings looks soft.
What's the optimum resolution for the Dwin HD500.
Best regards
Markus
Posted: Tue Sep 23, 2008 1:23 pm    Post subject:
Around 600 lines (progressive) from what I understand, assuming a 16x9 screen (ie: image area). I'm surprised you see scanlines at 1080i. That's really the best resolution by far as you don't want to downscale HD.
If I had a Dwin 500 I'd definitely run it at 1080i for everything. You can change the beam spot to be elliptical (taller than wider) if you still see scanlines.
beckma
Posted: Tue Sep 23, 2008 5:17 pm    Post subject:
Hello Kal,
thanks for you reply. That's what I finde out with my D50.
It's always best to run the native resolution. I wll try it again.
Kal do you also know the exact timings for Pal (576p) for my lumagen (front porch, active,total ....)
Best regards
Markus
Posted: Tue Sep 23, 2008 8:24 pm    Post subject:
Sorry, no, I don't know the exact timings for PAL 576P
Posted: Wed Sep 24, 2008 12:40 pm    Post subject:
beckma wrote:
Hello Kal,
Best regards
Markus
I asked this question in another thread. See here:
http://www.curtpalme.com/forum/viewtopic.php?p=142535&sid=fa601534ee173bf3cf1c2408d67651d4#142535
beckma
Posted: Fri Sep 26, 2008 7:25 am    Post subject:
Hello, Kal,
I tried 1080i again and it look smuch sharper.
But I can clearly see scanlines .
How do I make the dots oval on the HD500?
Has it electronic astig somewhere in the service menu or do I have to play with the CRP-magnet.
Any tips for playing with the CRP magnets.
Another problem is that with 1080i 47.97Hz the picture jitters.
1080i 50Hz with germen HDTV is fine.
regards
Markus
