Memory block warning / problem - BD808s
bengalfan
Posted: Mon Sep 22, 2008 2:54 am    Post subject: Memory block warning / problem - BD808s
Watched my Bungles go down in flames to Giants in OT, so turned set off & went outside to do some work (& maybe a couple more beers for attitude) Went back down to watch Cowboys / Packers game, but when I turned on the unit, no picture....... went to the s-link, had picture. Turned everything off & tried again. This time had message, memory blocks are full, press enter.... So I did, and had normal HD picture. Commercial came, I changed channel on HD source, and blocks message back again. Press enter, picture again.
Never had this before, so what's best suggestion, erase all blocks and start setting up all over? Or is there a simpler way?
Regards,
Van
The only easy day is yesterday
Posted: Mon Sep 22, 2008 3:00 am    Post subject:
Your going to have to delete any unused memory blocks. You've reached your limit... Shocked
One word of warning. DO NOT DELETE ALL BLOCKS unless you want to do a full set up from scratch !
