IWantMyHD
TV/Projector: Electrohome ECP 4100
| Posted: Mon Sep 15, 2008 12:33 am Post subject: Does anybody know where I can buy ECP Dallas chips? |
I am getting a jittery ECP menu and test grid on my Electrohome ECP 3100 and I figure my ECP 4100 is next to start showing problems. I think for the 3100 it might be the Dallas chip. Does anyone know how to get these with new batteries? I have copied the specs printed on the chip below:
ECP 3100: Dallas DS1230Y-150 Nonvolatile SRAM 9817M 100887
ECP 4100: Dallas DS1230Y-150 Nonvolatile SRAM 9829C 102325
Thank you!
| Posted: Mon Sep 15, 2008 12:37 am Post subject: |
Is the 3100 connected to a source or are you just trying to put up a test pattern? If it's not connected to a source, you will get jittery test patterns.
_________________ Chip
gonyr
| Posted: Mon Sep 15, 2008 12:54 am Post subject: |
First, make sure you have an active source connected. If that doesn't help, try reseating the all the chips on your boards by pressing gently on them - they'll probably make a slight noise as you do it.
I don't think a bad Dallas chip would lead to jittering - it's more for maintaining settings when the power is off. If you are convinced you need one, I think Curt carries them. If he doesn't, they're listed as in stock at http://www.futurlec.com/ICDallas.shtml
| Posted: Mon Sep 15, 2008 1:33 am Post subject: |
I do have some brand new ones here.
