sony vph1271 dark scenes to dark
schollman
Posted: Sun Sep 14, 2008 1:56 am    Post subject: sony vph1271 dark scenes to dark
Im fairly new to the crt world i have a vph 1271 &enjoy it but having a problem with dark scenes where its hard to see peoples faces and scenes is this a limitation due to the low lumens of this unit or a adjustment issue or due i need one of those cards with gamma adjustment ive seen? any help would be great!
Posted: Sun Sep 14, 2008 2:59 am    Post subject:
schollman,
A lot of variables come into play, so we need more info. Tell us a little about source(s) and how it's connected to the projector. Regardless, with CRT, if you're not using a device with low-level gamma boost you'll have to pick whether you want absolute black OR shadow detail down to the bottom. You can't have both without low-level boost.
More important, do you have a setup DVD such as AVIA or DVE or even a DVD with the THX Optimizer on it? Have you used a pluge pattern to verify you're not crushing or clipping blacks? Used it to adjust brightness? By what method did you adjust brightness and contrast?
Brooklyn
Posted: Sun Sep 14, 2008 4:07 am    Post subject:
What kind of set up have you done?
mike calcott
Posted: Sun Sep 14, 2008 4:35 am    Post subject:
Check G2 for correct setting, see advanced proceedures for this projector
Old dog learning new tricks
Arno P
Posted: Sun Sep 14, 2008 6:29 am    Post subject:
Bias up (with brightness on 50%) and/or G2 measured and adjusted should do the trick
"Obviously you're not a golfer"
