vince_b
| Posted: Wed Sep 10, 2008 1:13 am Post subject: Pronto Remote Codes found for MuxHD |
In utter frustration of getting the MuxHD remote to work, I found the thread here
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10500.html
and I don't think anything is wrong except the remote itself is sending very, very badly. I finally trained one code that worked, and plugged it into the very cool 'ir tool modified' combined with 'decodeir.dll' (both from remotecentral) and was able to decipher that it is an nec code with lots of garbage after it, and was able to generate clean codes for buttons 1-4. Wow, it actually works!
the settings in IR Tool:
carrier 0067
command 1-4 (as appropriate)
lead in 0168 00B6
lead out 0017 063E
and click encode hex, then paste into your prontoedit. You are using a pronto, right? If not, this might help anyway depending on what remote you use, since the IR Tool (with the dll extension) relates to the UIC remote codes from the Universal Electronics folks and there may be a way to get this to translate to other remotes.
here's the hex you can paste into prontoedit: (maybe this will help someone I hope)
<edit> Updated codes a bit, sometimes was having to press twice on button2, so added the original 'trash' at the end of the codes back, working better
button1:
0000 0067 002F 0000 0168 00B6 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 00B6 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0001 00B6
button2:
0000 0067 002F 0000 0168 00B6 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 00B6 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0001 00B6
button3:
0000 0067 002F 0000 0168 00B6 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 00B6 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0001 00B6
button4:
0000 0067 002F 0000 0168 00B6 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0044 0017 0044 0017 0044 0017 0044 0017 0044 0017 00B6 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0168 005B 0017 0F1F 0001 00B6
moome
| Posted: Thu Sep 25, 2008 7:53 am Post subject: |
thanks for informaiton
since All product (IFB-HD, XG-FHD, EXT-HD, IFB-FULLHD) use the same IR remote as MUX-HD,
user can use Pronto to select input source for these product~
