morlex13
| Posted: Wed Aug 27, 2008 7:16 am Post subject: 808 resolution |
hi guys
i woul like ask you this question:
i have a barco 808g whith hd144 lenses,it work with an htpc pluged on ports 3
my front end is zoomplayer with cyberlink decoder/ffdshow video processor
for you,what is the best resolution at the video card outpout and ffdshow outpout
to see only sd dvd?
i'm testing for the best compromise for minimum artifacts/best definition...
| Posted: Wed Aug 27, 2008 7:26 am Post subject: |
1440x960p
Gerbrand
| Posted: Wed Aug 27, 2008 8:23 am Post subject: |
1440x960 for NTSC, 1440x864 for PAL (1440x1152 is a bit too much).
Gerbrand
morlex13
| Posted: Wed Aug 27, 2008 10:54 am Post subject: |
| Gerbrand wrote: | 1440x960 for NTSC, 1440x864 for PAL (1440x1152 is a bit too much).
Gerbrand |
thanks
yes i'm in pal.
i put 1440*864 in video card output and too in ffdshow output?
Ile
| Posted: Wed Aug 27, 2008 11:55 am Post subject: |
| morlex13 wrote: | | i put 1440*864 in video card output and too in ffdshow output? | Yes.
Use 50 or 75Hz refresh rate for PAL material.
You can also try 1365x768 resolution, it works pretty fine for PAL. It gives bit sharper picture than 864p and 808 fan noise would be tab lower.
Gerbrand
