BG 1208/2 No Start
tri_joel
Posted: Tue Aug 26, 2008 9:17 pm    Post subject: BG 1208/2 No Start
It looks like everything is coming on except the the tubes and the fans. Where do I start?
Peace,
Joel
Posted: Tue Aug 26, 2008 10:55 pm    Post subject:
What are your leds on the G2 diagnostic board. What are on or off or dim or bright?
tri_joel
Posted: Wed Aug 27, 2008 12:29 pm    Post subject:
The red scan failure LED is on, it's just as bright as the green LEDs, all of which are on.
tri_joel
Posted: Wed Aug 27, 2008 3:43 pm    Post subject:
I just read Heywood's thread below. Sounds like this pj has the same problem.
www.vawinesnob.com
Posted: Wed Aug 27, 2008 3:54 pm    Post subject:
Well the scan fail means just that. Could be vert or could be horz. Projector would then go into HV shutdown. You also need to remember that a problem of the vert or horz circuits not getting correct voltage from somewhere else would also not allow scan to come up and would also result in scan fail. So you problem is not limited to the vert or horz boards. Now comes the fun part, finding the problem board/component. The only advantage you have as to a possible target board is from Curts post that the vert board failure is somewhat common.
Posted: Wed Aug 27, 2008 3:59 pm    Post subject:
Did you try tweaking the H width pot on the SMPS as Curt suggested in Heywoods thread?
