Barco Data 701 blows 0.125A fuse
Spotmatic
Posted: Thu Aug 21, 2008 3:59 pm    Post subject: Barco Data 701 blows 0.125A fuse
One of my projects, a Barco Data 701, keeps blowing the 0.125A fuse (the standby power supply fuse). Any ideas to track down the source of the problem? I have three new fuses left before I'd need to head back to the electronics store.
tommo2
Posted: Fri Aug 22, 2008 3:41 am    Post subject:
As far as I know, that fuse powers the CPU board and the remote sensors.
pull up the handbrake and walk away
Barco Data 701s
iScan HD scaler with sdi mod
Oppo 981HD with sdi mod
Xbox 360
Playstation 2
Denon AVR 1507 7.1 AV receiver
Wharfedale Diamond 9.4 floorstanders (front)
Wharfedale EVO2 (center)
Pioneer 100W (sides)
Wharfedale Diamond 9.1 (rear)
Wharfedale SW150 active subwoofer
Photos on the way!
Posted: Fri Aug 22, 2008 3:46 am    Post subject:
Could just be a pinched wire to the controller or IR cable then .
tommo2
Posted: Fri Aug 22, 2008 3:58 am    Post subject:
Try disconnecting the output of the standby power supply. If this solves the problem, the fault is a short after the supply (cpu board or remote sensors or associated wires).
If the fuse still blows, you have a fried standby power supply.
Barco Data 701s
Xbox 360
Playstation 2
Photos on the way!
Posted: Fri Aug 22, 2008 4:55 am    Post subject:
Tommo nailed it. THe standby supply is shorted.
