What Range 0-255 or 16-235?
ilias
Posted: Sun Aug 17, 2008 4:38 pm    Post subject: What Range 0-255 or 16-235?
I have a PIONEER DVR-550 player, and DVDO VP30 Scaler, if set them (both machines) in full range color (0-255 PC) the brightness must set too high, in the range of (26-235 VIDEO) the brightness and contrast is OK! But what is the correct setting?
My PJ is SONY G70 CRT with HDFury play in 1080p/60Hz!
Posted: Sun Aug 17, 2008 7:22 pm    Post subject:
Hope this helps...
http://www.audioholics.com/tweaks/calibrate-your-system/hdmi-black-levels-xvycc-rgb
Gino
Posted: Mon Aug 18, 2008 2:31 am    Post subject:
Great link Tom!
ilias
Posted: Mon Aug 18, 2008 7:22 am    Post subject:
Thank's Tom!!!!
jask
Posted: Wed Aug 20, 2008 4:40 pm    Post subject:
Thanks, great article.
ilias
Posted: Wed Aug 20, 2008 6:30 pm    Post subject:
I setup everything for 0-255 (PC) and i see little upgrade in the image!! ok! but why i like the 16-235 (VIDEO) image more? the new image is little dark, and the brightness of DVDO is high! the white images in TV program is very white!
Gino
Posted: Thu Aug 21, 2008 2:34 am    Post subject:
What I gathered from the article is you should be setting up everything to VIDEO levels
ilias
Posted: Thu Aug 21, 2008 1:07 pm    Post subject:
I put them all in VIDEO format!!! Now i think to bye a Panasonic bdp 30 blue ray! how best picture i can get?
Posted: Thu Aug 21, 2008 2:12 pm    Post subject:
The article indicates that ALL video content we use (DVDs, BluRay, etc) is stored in 16-235 format, so you should display it the same way. It also says you should get a source of blacker-than-black (DVE, or the THX Optimizer on any THX disk), and if you can raise the brightness and see the BTB signal, you've got it set right.
ilias
Posted: Thu Aug 21, 2008 3:46 pm    Post subject:
Yes i do that, my setup 0-255 is whith the THX OPTIMIZER, but the image is little darker, lost some details in dark, and the brightness in the SCALER is very high, then i back in the VIDEO 16-235. I think is better for my eyes!!
But all this setup again because IFB-FULLHD HDMI 1.3 !!!! now i have the HDFury, the card comes September-Octomber.
Brian Hampton
Posted: Thu Aug 21, 2008 6:35 pm    Post subject:
After reading that....
I'm setting up for Video Levels.
I believe the PS3 re-maps RGB when set to full and I guess it does a fantastic job of it but Video levels seems "correct" so I'm going to set that up.
-Brian
Posted: Thu Aug 21, 2008 11:46 pm    Post subject:
I wonder if you did the blacker than black adjustment for R, G and B individually to get each color to just pass it then combine them for a 20 IRE color temp test how it would measure out VS how it would actually look shadow detail wise?
I wonder how many would prefer more detail in the lower end VS accurate color
Posted: Fri Aug 22, 2008 3:09 am    Post subject:
My older plasma is like that. Plenty of detail in the low end, but it's all green! Thumbs Up
