bigsilverdisc
| Posted: Fri Aug 15, 2008 12:55 am Post subject: THX Optimizer |
Hi
I gave my audio a test with one of those "THX optimizers" you find on certain DVD's and while doing the pink noise test on all the speakers i did not get any sound out of the Subwoofer, when i run the internal test out of my amp I do.
I also did the In & Out of phase test and all the front speakers gave me the In & Out Sound but when it came to the rears all I got was the In Phase Sound.
Why is this do yo think, all the speakers check out when doing the Amp's internal Test?
Cheers
| Posted: Sun Jan 11, 2009 7:07 am Post subject: |
How is the device connected to the amp and is it set to the correct decoding method? It sounds like a connection error or a wrong selection somewhere there.
| Posted: Sun Jan 11, 2009 3:06 pm Post subject: |
If it's connected via SPDIF, then your DVD player is probably setup to output 2-ch PCM instead of discrete DD/DTS. Go into your DVD player's setup menu and configure it to output "bitstream" - NOT PCM - and you should be good to go.
