timf
Joined: 07 Jul 2007 Posts: 102 Location: Adelaide South Australia
| Posted: Fri Aug 08, 2008 5:49 am Post subject: Okay, what is it this time |
After having problems with a dim G tube, buying a Sencore CR70, testing all tubes, finding that they are okay and replacing a blown R neckboard, more problems on my BD808s.
Starting setting up the pj this moring, fed it a 1080i signal and hear about 3 "cracks" not one after the other but spaced about 20 mins apart, the image shudderd slightly but everything was okay.
Worked on it for a couple of hours and then turned it off to take a break and about an hour or so later went back to continue on with the set up.
Turned it on.......no picture, tubes dont light at all, theres no Red LEDs's lit up in the back, thers nothing indicating what the problem could be.
Over the gurus yet again, any suggestions on what prob i have this time?
Cheers,
Tim
