HELP: Barco 1208/2 troubleshooting
KES
Posted: Thu Aug 07, 2008 12:27 am    Post subject: HELP: Barco 1208/2 troubleshooting
My Barco 1208/2 just developed a new issue. After a few minutes of operating fine, the tubes go dark. The light on the back of the PJ stays green. The fans are still running. If I place the PJ into standby, and then select the proper input. The tubes will come back on for a minute or two, and then go dark again. Anyone have an idea what and where the problem is. I have a second 1208 available for parts here. Confused
What does not kill you, makes you stronger.
KES
Posted: Thu Aug 07, 2008 1:25 am    Post subject:
OK, I checked the boards and found a red light on the EHT board. Replaced it with a spare. PJ worked for a couple minutes then went dark. The red light is now on the spare EHT board. Any ideas out there as to what to try now?
r.bauer
Posted: Thu Aug 07, 2008 5:54 am    Post subject:
Probably the EHT-Quadrupler that has gone bad. Other possibility is the EHT splitter, but the Quad is first choice.
Swap it and you'll be fine.
KES
Posted: Fri Aug 08, 2008 2:40 am    Post subject:
Thanks r.bauer. You were right on. Switched out the quadrupler and the PJ is back to life! Thumbs Up
