dbaisey
Joined: 09 Mar 2006 Posts: 821 Location: Southern Cal LA / Seattle WA
| Posted: Mon Jul 28, 2008 10:44 pm Post subject: Actual end users of HDMI DA's advise needed. |
I need to find a working solution that will take one HDMI feed and pass the signal intact to four locations min. I have researched this but most are could, should and would type replies. Need can do it.
The end display will be the Moome new XG Full HD card on one of the outs and the sources will include a PS3, HD-DVD, BR player and hopefully ran from the output of the Lexicon MD12 HD. Thanks in advance, I already know some tweaking will need to be made in the control system orgates and macros but if anyone is doing it I would like to know which product does it. To add to it it needs to be RS232 controlled unless passive on all the time is not a issue. Thanks, Doug
If this needs to be moved to source devices no problem.
