Marquee 9500LC Red Tube question
Arno P
Posted: Sun Jul 20, 2008 10:44 am    Post subject: Marquee 9500LC Red Tube question
Just powered up my new 9500lc and the red tube shows as if G2 is too high (and re-trace lines are visible). The Menu G2 does not seem to change this and I wonder if it is due to some internal G2 setting (had a 1272 before and this was adjustable)
Any clue?
EDIT: Solved....the combination of brightness and G2 adjust did it Wink
Topic closed
 Filesize:  14.24 KB
 Viewed:  1385 Time(s)
"Obviously you're not a golfer"
