Barco BG 801s semi dead
sCREEm
Posted: Sun Jul 20, 2008 10:03 am    Post subject: Barco BG 801s semi dead
Red led at back is on, set is pulsing, just before the set "died" the green flickered a few times, fans turns for half a second, the stops (sounds like PSU shuts down).
Any idea where to look ?
papalek
Posted: Sun Jul 20, 2008 1:52 pm    Post subject:
Pull the leads from the HV splitter one at a time (with it off) and try to turn it on with one lead removed at a time. I have had bad tubes do the same thing. If it is a bad tube the PJ will start like normal with the lead pulled for the tube that is bad.
I do love my AmPro's
sCREEm
Posted: Sun Jul 20, 2008 2:53 pm    Post subject:
no change, problems seems to be with the psu board (most likely because a dead capacitor on the H def board)
Posted: Sun Jul 20, 2008 5:18 pm    Post subject:
You have a short somewhere, loading the power supply down. It could be any board in the set. Pull all boards one at a time save for the power supply and controller board. If it still pulses, you'd need to send in or swap the SMPS. I can repair any board if need be.
