vespaman
| Posted: Sun Jul 20, 2008 6:55 am Post subject: How to accomplish 24P on a CRT projector? |
With 24p-only material getting more and more common, I am starting to think about the next step in my set-up.
This is what I have today;
Source: Tvix 6500 outputting 1080p HDMI to
AVP: Onkyo 905 forwarding the 1080p HDMI to
Converter: HDFury
Proj: Marquee 9500 (modified with color corrected lenses, and various electronics)
The Tvix can let the output fps/frequncy follow the material, i.e. when playing 24p material, it can switch to this. So this part is probably ok.
The Onkyo cannot do any processing (afaik) on 1080p24.
Obviously the projector is not doing 24p well. Not sure about the HDFury.
So, I need a recommendation on how to proceed. I have already (more or less) decided to go with the new Moome HDMI 1.3 ext box, so I can get gamma correction among others, and hopfully better handling of 50p, which the HDFury shifts too much right. If I also get a sharper pic, that would be a bonus.
But how to do 24p? I guess I need a proper VP? Or is there any simpler (read: lower cost) solution. I guess just doubling or trippling the scan rate would do it for me.
I have no need for scaling, since I only watch 1080i or 1080p, the Tvix cannot auto output the i/p, so I let it do the deinterlacing when needed. Not optimal (I guess the Reon in Onkyo might do this better), but nothing I can do about it.
If it wasnt for HDCP, I guess I should go for a full VP directly into the Marquee. But I like to be able to cope with HDCP when needed...
Gino
| Posted: Sun Jul 20, 2008 7:05 am Post subject: |
You'll need a VP to frame double or triple for you so you get 1080p48/72. CRT won't show 24p, refresh is too low.
The Lumagen Vision HDP would be your cheapest bet, then this would connect to your Moome.
vespaman
| Posted: Sun Jul 20, 2008 8:37 am Post subject: |
| Gino wrote: | You'll need a VP to frame double or triple for you so you get 1080p48/72. CRT won't show 24p, refresh is too low.
The Lumagen Vision HDP would be your cheapest bet, then this would connect to your Moome. |
I was a afraid of that
.. but reading the sales stuff on the Vision HDP, it says input 720p, 1080p24, but does not mention 1080p50 or 1080p60?
Gino
| Posted: Sun Jul 20, 2008 9:20 am Post subject: |
The moome external has multiple HDMI inputs, so you can go direct with 1080p60 into it as you'd want that for video material anyway, that is if the HDP doesn't support it.
vespaman
| Posted: Sun Jul 20, 2008 9:43 am Post subject: |
Infact, the new Moome 1.3 ext box only has one input. But anyway, even if it would have two inputs, I am not sure this a good set-up, since I would then have two paths from the 905 (one through the VP, and one direct to the Moome), depending of what material to watch. Complicates things too much for the casual user, that does not know how to check if the material is 24p or anything else.
And, afaik, there's no way to select the ouput "on the fly" on the Onkyo, you have to go into the menu system to bind the output to the input.
It seams that RadianceXD does 1080p60 on the inputs, but using that box only for my purpose would be a crime. Also a larger hole in my wallet than I would like too.
Gino
| Posted: Sun Jul 20, 2008 11:17 am Post subject: |
Sorry, haven't paid much attention to the new moome external, I was thinking about his previous one obviously.
What's your budget? You can find cheap second/b-stock VP50's for less than $2K I believe.
If you can send 1080i60 out of your other devices, the HDP can then deinterlace it back to 1080p60 for you.
nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
| Posted: Sun Jul 20, 2008 7:38 pm Post subject: |
Id do this first , sell the HDfury, and I wouldnt use the Onkyo for any video feed to the Marquee. no matter what they say about it video capapbilities most here would agree it would only degrade the picture.
1)Replace the HD fury With moomes HD-MUX DVI repeater to take care of HDCP and add 4 HDMI inputs at once.The optical can cary the audio from the HDMI compressed 7.1 acording to the specs if not add a HDMI spliter before the MUX to get full HDMI audio to the Onkyo via HDMI for Bly Ray sources in the future. Then you can use either the HDMI out or the DVI out to:
2) a lumagen HDP or HDQ (Both used) have this now output 1080p to the Marquee via RGBHV
This will give you many more input option for future expansion of sources and the Lumagen will not only take care of Gamma better(11 point gamma) it also has color gammut controls for primaries and secondaries so greyscale and primaries and secondaries can get the full attention they may need. the moome external ony will give a general boost to gamma with out the precise control that any Lumagen product will now give, also Lumagen is always adding new features via firmware updates .
if you are patiant and look for a lumagen and get the Moome HD-MUX you'll have everything you'll need for a long time for close to $ 1000 or a little more.
vespaman
| Posted: Sun Jul 20, 2008 8:56 pm Post subject: |
According to the FAQ on this site, they only ship within US, so I'll have to pass on that one... But thanks anyway!
vespaman
| Posted: Sun Jul 20, 2008 9:12 pm Post subject: |
| Nashou66 wrote: | Id do this first , sell the HDfury, and I wouldnt use the Onkyo for any video feed to the Marquee. no matter what they say about it video capapbilities most here would agree it would only degrade the picture.
1)Replace the HD fury With moomes HD-MUX DVI repeater to take care of HDCP and add 4 HDMI inputs at once.The optical can cary the audio from the HDMI full uncompressed 7.1 acording to the specs if not add a HDMI spliter before the MUX to get full HDMI audio to the Onkyo via HDMI for Bly Ray sources in the future. Then you can use either the HDMI out or the DVI out to:
Athanasios |
OK, I was looking at the HD-MUX a few hours ago. And yes, using it as a pure HDCP stripper is appealing. I do not think that I will get any HD sound out of it though, so I need a HDMI 1.3 splitter before it, or stay with the Onkyo in the video chain. The Tvix already does HD sound, and I don't want to spend one day without it
And by the way, my own test going straight or through the Onkyo shows no difference, at least when using the HDFury and 0-255 levels all the way in my setup. But this may of course be more visible with a moome or lumagen RGB output.
The only worry I have, is that I am not sure that the Tvix can do auto between 1080i50, 1080i60 and 1080p24. I have asked on mpcclub, but have yet to get a confirmation on this. I know for a fact that I can set it to auto switch between 1080p50, 1080p60 and 1080p24, but that, afaik wont be accepted as an input to the HDP or hte HDQ.
But if the Tvix can go between the i50/i60 and p24 this is probably the way forward! The Dollar rate to the Swedish Krona is very good at the moment, so is is a good time to "invest"
Is there any comparison done between the Lumagens and Moome units (regarding analog output quality)?
| Posted: Sun Jul 20, 2008 9:25 pm Post subject: |
| vespaman wrote: | | Nashou66 wrote: | Id do this first , sell the HDfury, and I wouldnt use the Onkyo for any video feed to the Marquee. no matter what they say about it video capapbilities most here would agree it would only degrade the picture.
Athanasios |
Is there any comparison done between the Lumagens and Moome units (regarding analog output quality)? |
the HDP/HDQ will accept 1080p24 no problem, I have not tried 1080p/60 and do not think it accepts this for sure. One nice thing about the HDP/HDQ you can set the EDID controls for each input individually so you can Force the Tivix to output which one you want, and also each input on the HDP/HDQ has 4 more memories so for instance you will be connecting the tvix to say input 1(dvi) of the lumagen, set input 1 memory A on the lumagen for 1080p24, input 1 memory B for 108050i and input 1 memory C for 1080i60 now when you switch memories on Input 1 of the lumagen the Tvix will send out that resolution theoreticly. I have my LG BH100 blu ray player set up like this, i ahve it set for 2 input rez's on my lumagen, 1080p24 and 480i for SD. the BH100 should not output 480i from its HDMI port but the Lumagen fools it to force it out, now i get the superior scaling of the Lumagen for SD DVD. I do think this would be a great solution for you.
vespaman
| Posted: Mon Jul 21, 2008 7:10 am Post subject: |
| Nashou66 wrote: | | Quote: | | Is there any comparison done between the Lumagens and Moome units (regarding analog output quality)? |
The HDP/HDQ do not pass audio, you need the 4400 dollar radiance for that.
Athanasios |
That's OK, it will be last in the chain anyways;
| Code: |
Tvix->Onkyo->HDMux->Lumagen->Marquee
or possibly
| Code: |
Tvix->HDMI1.3 Splitter->HDMUX->Lumagen->Marquee
->Onkyo
But my question (analog output) where more towards the video quality between the Lumagens and the Moome; with lumagen having some years on it's sholder, maybe the new Moome Ext HD has a better pic all in all (with the help of the VP)?
In that case a better set-up would perhaps be;
| Code: |
Tvix->Onkyo->Lumagen->Ext HD->Marquee
| Posted: Mon Jul 21, 2008 10:47 am Post subject: |
I would use the Mux as it strips HDCP so you can use the rgbhv outs which looks very very good. But if you can wait for the next HD-VIM card from moome then you wont need the MUX to strip HDCP, or the EXT HD. so if HDCP is not an issue for you now get the lumagen and use its RGBHV's and later when Moome makes another batch of HD-VIM's you can go to Blu-Ray and have an all digital path.The moomes EXT HD analog should be no better than the Lumagen where you get superior scaling. I wouldnt get the EXT HD.
