mjaco
| Posted: Sun Jul 13, 2008 2:01 pm Post subject: What HDFury do i need ?? |
I have an optoma ep725 prjector setup to my xbox 360, ps3 and wii. Xbox is setup via vga cable, wii via composite and ps3 is setup via a vga to component cable which doesnt work very well due to a blurred horizontal line in middle of the screen when gaming. I was wondering what Hd fury would suit me best and would it work ???
Matt
HKmod
Joined: 27 May 2007 Posts: 1600 Location: Taiwan / France
| Posted: Fri Jul 18, 2008 10:09 pm Post subject: |
Hi Matt,
Setup your X360 to 1280x720 and see if it's displayed correctly, do the same for 1920x1080
If your display accept and resolve 1280x720 and/or 1920x1080 it means that you will be able to get HDMI 720p and/or 1080p displayed on your screen while using HDfury. (solving your issue at the same time)
It's simple as that !
_________________ HKmod.com - We ship worldwide
(Site under recalibration)
raj mandary
| Posted: Mon Aug 04, 2008 12:05 pm Post subject: |
Welcome! You have entered [The Lounge] at 2:43 pm
[raj mandary] 2:49 pm: hi i need a solution-i have a lg dvd player with HDMI output,however my plasma panel does not have hdmi in ,but it has rgb,component and dvi.I am unable to get any picture on the plasma when i connect the dvd to the dvi on the plasma.I am told the problem is that the plasma is not HDCP,is there any solution for this.Then i would never be able to get the best of pictures on this plasma through its HDMI socket if ever i buy a blu-ray player in near future ,please advise if you have the solution
_________________ I have purchased a lg dvd equipped with an hdmi output,and i have not been able to connect the device to my plasma tv input dvi,however i could connect same to the component on the plasma and it work well.
The problem for non connection through the dvi input on the plasma is apparently the plasma is not HDCP compliant,my plasma do have RGB input and i have been able to connect my laptop,and it displays well.
I would like to know if you have a solution to this problem.As i also want to acquire a blu-ray disc player this month i really need a solution as i would not be able to enjoy the best of pictures on the plasma which does not have a HDMI input,is not HDCP compliant ,and is not presently working from my dvd hdmi to dvi plasma....looking forward for a solution from you
raj mandary
| Posted: Mon Aug 04, 2008 1:01 pm Post subject: |
any reply pl
| Posted: Mon Aug 04, 2008 5:46 pm Post subject: |
| raj mandary wrote: | | any reply pl |
Give us a chance to wake up over here. You posted at 7am then asked again at 8am.
What's the model number of your Plasma? When you run your laptop can you use 1280x720 into it and get a proper picture?
