bohnenblust
| Posted: Mon Jul 07, 2008 7:18 pm Post subject: Barco Graphics 808s horizontal lines |
New to CRT PJ and cant figure this one out for the life of me.
I cant figure out what the horizontal lines on the picture in the darker images is. It appears to be in the blue realm, but I am not sure
I am running a progressive DVD player with a composite transcoder to the RGBHV input in the back of the CRT.
Adam
| Description: |
87" screen (DIY not painted yet.) |
| Filesize: |
83.52 KB |
| Viewed: |
9207 Time(s) |
| Posted: Mon Jul 07, 2008 8:34 pm Post subject: |
Adam disconnect all input sources. Do you still see the diagonal lines with no input signal ? Next reduce brightness and contrast and look through the lenses at the CRT's themselves.
bohnenblust
| Posted: Tue Jul 08, 2008 1:14 am Post subject: |
How do you keep the CRT on with no input?
It was on the blue face But it isn't moving at all could it be burn?
| Posted: Tue Jul 08, 2008 1:37 am Post subject: |
The point is the with the projector turned on and no input the tubes should all be dark. Is the Blue CRT still lit ?
bohnenblust
| Posted: Tue Jul 08, 2008 1:42 am Post subject: |
Ahhhh, Yes the blue tube is still lit and it has a lot of noise on it including flashes on the bottom.
| Posted: Tue Jul 08, 2008 1:59 am Post subject: |
Double post...
bohnenblust
| Posted: Tue Jul 08, 2008 2:01 am Post subject: |
I have a spare PJ of the same specs with a very burnt blue.
Which should I try first?
| Posted: Tue Jul 08, 2008 2:07 am Post subject: |
Swap the Blue neck board. Sounds like a G2 short in the CRT though. Did it just suddenly happen ?
bohnenblust
| Posted: Tue Jul 08, 2008 2:09 am Post subject: |
no it seemed to be on the crt the whole time I have had it.
| Posted: Tue Jul 08, 2008 2:16 am Post subject: |
Do a search for Sencore on this forum.
bohnenblust
| Posted: Tue Jul 08, 2008 2:19 am Post subject: |
What is that?
bohnenblust
| Posted: Tue Jul 08, 2008 2:50 am Post subject: |
Just changed the neck board and the lines appear to be lessend but when I viewed the tube with no input there was a constant blue flash at the bottom of the face. Is that a bad thing? it does not do that with the inpout on.
| Posted: Tue Jul 08, 2008 3:13 am Post subject: |
Can you post a screen shot ?
bohnenblust
| Posted: Tue Jul 08, 2008 3:14 am Post subject: |
Sure of what the tube face or another movie?
It would be neat to see if the Sencore would help the tube.
| Posted: Tue Jul 08, 2008 3:18 am Post subject: |
Blue tube face with no signal and projector on.
bohnenblust
| Posted: Tue Jul 08, 2008 3:22 am Post subject: |
I cant get it to show the little flare of the bottom after it has warmed up and the movie has been going for a while, not even the lines are apparent.
Ill try tomorrow.
| Posted: Tue Jul 08, 2008 3:31 am Post subject: |
Sounds like maybe it's fixed. Reset the G2 levels.
1031
bohnenblust
| Posted: Fri Jul 11, 2008 10:30 pm Post subject: |
How do I reset the g2 levels on the barco, I printed both the manuals and cant seem to find a process to do this.
