Brooklyn
Joined: 17 Sep 2007 Posts: 494 Location: Morgan Hill, CA
| Posted: Fri Jul 04, 2008 7:14 am Post subject: Corner/Side Focus is bad on Nec 6PG |
The focus of my Nec 6PG-6000 on the far left and right sides, as well as the corners is abnormally bad, imo. It is not an optical issue, as I can look into the lenses and see the raster has poor focus. The center focus is great. It occurs on all 3 CRT's. I max out the corner focus control, but it is still pretty bad. Is this a focus board problem or?
deronmoped
| Posted: Fri Jul 04, 2008 4:07 pm Post subject: |
Could be the focus board, does adjusting it change anything. Could be that the astig needs adjusting.
Deron.
| Posted: Fri Jul 04, 2008 4:14 pm Post subject: |
Most likely a bad focus board. Just repaired two this morning.
