BradTheAggie
Joined: 08 Mar 2006 Posts: 651 Location: Oak Point, Texas
| Posted: Fri Jun 27, 2008 6:25 pm Post subject: Geometry question on my Marquee |
When I first bought my 8000, I sat it on a low coffee table in front of my couch. I have since built a ceiling mount, consisting of very heavy duty (600 lb rated) steel tube and mounting plate, bolted to aluminum rails that then bolt to the Marquee. I have noticed that now the geometry of the bottom of the picture is now distorted, with a roughly "tilde" shape to it, just like the "~" character of a keyboard. I assume the steel mounting plate is affecting the magnetic field of the green tube causing this distortion, and that fixing this distortion will require adjusting the magnetics of the tubes. Is this assumption accurate, and if so can anyone give me any tips on how to proceed?
Brad
_________________ (bholman on the AVS forum)
