setting 1080p on a 1209/2 via port 3
DisTreSs
Posted: Sat Jun 14, 2008 2:12 pm    Post subject: setting 1080p on a 1209/2 via port 3
I just set up a very sweet looking 720p picture on my 1209/2 without a hitch, but moving on to 1080p seems to give me some issues.
Basically it would seem that the raster is not big enough for the 1080p picture.
When I set a 1080p resolution (on port 3 btw) the picture just wraps aroung the edges of the raster. There is more than enough room on the tube left itself mind you, it's just that the raster is too small at that resolution...
Is there something that can be done about this?
Greets and thanks as always Wink
jkruger
Posted: Sat Jun 14, 2008 6:31 pm    Post subject:
It seems like I have heard that port 5 is the preferred input for 1080p. I have not tried to go higher than 1080i myself, and have not used port 3 at all.
DisTreSs
Posted: Sat Jun 14, 2008 6:51 pm    Post subject:
Hi, thx for the reply.
I noticed that you have a 1209s and in your case I would go for port 5 too. Unfortunately, my port 5 (since I don't have an s version) is not as flexible with regards to inputs so I have no choice but to go for port 3.
On 720p it's great though (very sharp despite the lack of scheimpflug and easy convergence) which is why I wanted to step it up and try 1080.
I hope someone can chime in so I can get this puppy up to where it belongs Wink
r.bauer
Posted: Sat Jun 14, 2008 7:53 pm    Post subject:
Your problem is related to porch timings in the video signal. This can only be really solved with a scaler that allows you to adjust the porches, such as a CrystalioII or a VP50pro.
What is your source?
DisTreSs
Posted: Sat Jun 14, 2008 8:03 pm    Post subject:
Hi, I used an Xbox 360 for this...
I just tried with my pc attached but then I get a 'pan&scan' desktop if you know what I mean...
The whole desktop won't fit but when you move the mouse you can see the rest of the desktop as the picture scrolls Very Happy
This could ofcourse be a driver issue (as for instance the monitor is still defined as a default monitor) but then again, this problem does not show on 720p.
If this is also a porch timing matter, I could use Powerstrip to set it correctly of course but to be honest, you will have to tell me how to achieve this since I have no idea of the values required Wink
grogthegreat
Posted: Sat Jun 14, 2008 11:38 pm    Post subject:
DistreSs: You just described the exact problem I have on my sony 1292 and I can tell you that powerstrip doesn't seem to help. I'm very new to powerstrip but can't shrink the cropped desktop image to fit inside the raster. I can move the cropped picture around. I can extand and contract the cropped image as well but can't get more of the desktop to be shown.
I'm still working on the problem so I'll post if I find one!
-Greg
First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
TbX
Posted: Sun Jun 15, 2008 8:00 am    Post subject:
Hi
lowering the turn over point for short retrace can solve this
//TbX
grogthegreat
Posted: Sun Jun 15, 2008 7:43 pm    Post subject:
Sorry if it seems like I hijacked this thread but since DisTreSs and I have the same problem I might as well as the following question:
Is the 'turn over point' a variable in powerstrip? If so, where is it? Also, can you adjust hight as well as width?
I'll keep looking as searching the forums didn't find it. Thanks for the help as this seems to be the problem!
-Greg
-Curt Palme
TbX
Posted: Sun Jun 15, 2008 8:41 pm    Post subject:
i don't now if this works on all projectors
but i lowered the turn over point for short retrace on my old 1209 to ca 60KHz
and it worked fine this is done in the projector not on the source
//TbX
grogthegreat
Posted: Sun Jun 15, 2008 10:02 pm    Post subject:
Sounds like exactly what DistTreSs is looking for. I have a sony 1292 so I don't know if I can adjust that on mine and if so, where. I might start my own thread soon if searching continues to come up with nothing. Thanks,
-Greg
-Curt Palme
DisTreSs
Posted: Tue Jun 17, 2008 7:26 am    Post subject:
//TbX
Hey TbX, could you instruct me on how to do this?
thx Wink
Ile
Posted: Tue Jun 17, 2008 10:20 am    Post subject:
In 1209 high freq mode chancing point is adjusted by turning P1 pot from vertical deflection module. Green led in horizontal deflection sub board indicates when high freq mode is used.
I'm not sure if this is help with Xbox timings though.
Extended desktop is another thing, it's caused by pc video card. It could be that your another display resolution is limited to smaller resolution and that's why video card use extended desktop. Test only projector output activated or projector as main display.
DisTreSs
Posted: Tue Jun 17, 2008 12:27 pm    Post subject:
Hi Ile, thx for the info.
With regards to the extended desktop though: the video card should not be at fault since when I attach my 808s, there is no extended desktop...
Posted: Tue Jun 17, 2008 3:33 pm    Post subject:
You need to go into your video driver setting's and tell it your maximum resolution. If it thinks your max resolution is 1280x720P for instance and you go 1920x1080P it will only output the 1280 signal and make you scroll around. It's called virtual desktop. It's a PITA most of the time.
TbX
Posted: Tue Jun 17, 2008 6:45 pm    Post subject:
ile beat me to it
it worked for me with hddvd 1080p same problem as above
//TbX
