Zenith PRO 851X and the Toshiba HD D1 DVD Player
electronics
Posted: Fri Jun 13, 2008 12:56 am    Post subject: Zenith PRO 851X and the Toshiba HD D1 DVD Player
OK everyone I wanted to share my experience after I connected a Toshiba HD D1 high definition DVD player to my Zenith PRO851X CRT projector. The player was set at 480i with a composite video connection. The picture and color reproduction was outstanding. I actually saw the de-interlacing when I was near the screen. The only explanation I have is that the throughput of the DVD player is higher than 480i and the de-interlacing circuitry of the projector yielded a progressive scan picture at the maximum resolution which I suspect is much higher than 480i. What are your thoughts?
Posted: Fri Jun 13, 2008 1:05 am    Post subject:
Hello
If the Zenith will support 1080i by component, that should look better still. Taking 480i out of an HD DVD player is like driving a Ferrari on regular gas and cheap tires, the potential is totally choked.
Posted: Fri Jun 13, 2008 1:22 am    Post subject:
851 is maxed out at 480i. Sad
Brooklyn
Posted: Fri Jun 13, 2008 2:10 am    Post subject:
Yep, you are seeing a standard definition(480i) picture via composite video. I would have to say that you are easily impressed Wink Just wait until you see a calibrated HD picture from a higher end model of projector.
Posted: Fri Jun 13, 2008 2:22 am    Post subject:
I will say though, having had an 851 myself, many years ago, that it did produce a pretty nice picture, even at 480i.
