CunnazZ
| Posted: Sat Jun 07, 2008 4:07 am Post subject: Sony 1292 H-size Issue :-( |
Does anybody know of a way to increase the horizontal size on a 1292?????
On my old 1252 there was an adjustment inside the projector that increased the size of the raster area, does the 1292 have anything like this.
I have maxed out the projectors size control and I still cant get my image big enough on the tube face
Thanks in advance
Nathan
Atom
| Posted: Thu Jun 12, 2008 5:04 pm Post subject: |
I don't think that the 1292 has any way of increasing the size of the picture within the raster. What are you using for an input source ? If it is a HTPC then you can use Powerstrip to set the horizontal porches to get the correct width
Andrew
grogthegreat
Joined: 16 May 2007 Posts: 166 Location: San Diego, CA
| Posted: Thu Jun 12, 2008 7:27 pm Post subject: |
I'm in the middle of setting up my 1292 for the first time so I'm no expert but you could you try 'RGB size'?
Sorry if that doesn't help but it is the only thing I can think of!
-Greg D.
_________________ First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
CunnazZ
| Posted: Sun Jun 15, 2008 12:57 am Post subject: |
Yes it is a HTPC as a source but every time I install powerstrip it crashes my computer so am trying to avoid it for now
Yes I have maxed out the RGB size control.
I have used the small amount of adjustment within the CCC to make the pic as big as possible and that seems to be not to bad, so will just live with it that way for the time being
Thanks for your advice
Nathan
Graham Johnson
Joined: 07 Mar 2006 Posts: 241 Location: Melbourne Australia
| Posted: Mon Jun 16, 2008 11:12 am Post subject: |
I bet you are in a PAL country.
1080i 50HZ is a real problem for the 1292.
50hz HD sources have an absolutely ridiculous front and back porch size. So much so that many CRT projctors just havent got enough width amplification to fill the raster.
I couldnt fix a HDTV setop box I had and had to sell it. One box I owned actually had 1125i as well as 1080i and fixed the problem.
Bite the bullet and make power strip work.
_________________ Graham
