kjelli
| Posted: Fri Jun 06, 2008 12:39 pm Post subject: 2 X Barco 808S, different article number. Same machine? |
I need to know if a Barco 808S with article number R900902 is the same machine as one with article number R900903? Is all the cards in them interchangeable?
Cheers
Kjell
jkruger
| Posted: Fri Jun 06, 2008 1:22 pm Post subject: |
Being one number apart, they should be. The boards are all numbered, if they don't match, don't swap them.
David_Web
| Posted: Fri Jun 06, 2008 2:47 pm Post subject: |
Could it be that one is Iris/2 and the other Iris/3?
_________________ SNR of people are ridiculously low.
r.bauer
Joined: 08 Apr 2006 Posts: 280 Location: The Netherlands
kjelli
| Posted: Mon Jun 09, 2008 12:46 pm Post subject: |
ok, thanks guys. After checking, one is actually Iris2 while the other is iris3.
I'll open them up and have a look at the numbers, (if I can figure out what number to check, at first glance all the numbers marked on a stickie on top of the cards all had the same number).
google?
Kjell
secstate
| Posted: Wed Jun 11, 2008 1:19 am Post subject: |
The number on the tops of the boards is usually the serial number of the projector they are from. The part number is usually on a sticker on the bottom part of the board on the gray connector that connects to the projector when the board is inserted. Barco board numbers usually start with R76.
kjelli
| Posted: Thu Jun 12, 2008 9:16 am Post subject: |
Thanks. I have checked almost every card, and everyone do have identical numbers
Kjell
r.bauer
| Posted: Thu Jun 12, 2008 9:48 am Post subject: |
Check the EHT, EHT-quadrupler and EHT-splitter. These parts can have different numbers, and if they do they cannot be interchanged.
kjelli
| Posted: Fri Jun 13, 2008 10:27 am Post subject: |
ok, thanks , i will check these in particular.
K
