Boilermaker
| Posted: Sat May 31, 2008 8:33 pm Post subject: XG G2 setting problem - Advice needed |
I have done a few XG G2 adjustments using the excellent "NEC XG G2 Calibration" guide in the Advanced Procedures Section and all has gone well.
This time, however, I ran into a snafu. First, all the G2 voltage checks with AKB test switch on were right on 2.5 volts as they should be. All went well until Step "E" where "Bright Gain" is adjusted. I had to adjust it all the way to zero to get the black edges of the two ramps to meet.
My test signal was from the Avia disc in a Panny Blu-Ray set to 1080i on the component output. I also noticed that I have to set brightness at 100% to get close to not crushing all blacks.
It almost seems that I have a colorspace problem, but I don't think that is it.
BTW - The other times I have done this successfully, I was using a VP50 scaler for the signal - Shouldn't really matter!
Any ideas on what I am missing?
Bob
Boilermaker
| Posted: Sun Jun 01, 2008 10:09 am Post subject: |
Bump - Anyone done this before?
Thanks;
Bob
| Posted: Sun Jun 01, 2008 1:25 pm Post subject: |
Start again from scratch...
Sometimes this just goes haywire. Start over.
Boilermaker
| Posted: Sun Jun 01, 2008 2:58 pm Post subject: |
Thanks! I'll give it a shot.
BTW, are you getting the new high bandwidth blenders from TVOne? They still are claiming a mid June delivery, so I'm getting anxious!
| Posted: Sun Jun 01, 2008 8:58 pm Post subject: |
No, one projector uses enough electricity for me.
MikeEby
| Posted: Sun Jun 01, 2008 9:05 pm Post subject: |
| Boilermaker wrote: | Thanks! I'll give it a shot.
BTW, are you getting the new high bandwidth blenders from TVOne? They still are claiming a mid June delivery, so I'm getting anxious! |
I don't think that was Mark, he considers two projectors in one theater an irresponsible waste of energy, if I am not mistaken
But I am looking forward to hearing about your results.
Edit: he beat me to it!
Boilermaker
| Posted: Sun Jun 01, 2008 9:39 pm Post subject: |
My bad! Actually as long as twice a many people view it, I think it should be more efficient than a single projector setup!?!?
Boilermaker
| Posted: Tue Jun 03, 2008 12:59 pm Post subject: |
Mark - My problem is that I am too impatient! Sure enough, I just normalized all the settings first and everything fell into place.
Thanks for the advice!
