Flicker problem from HTPC via VGA to Panasonic PT-M1085
digitalsdc
Posted: Thu May 29, 2008 6:52 am    Post subject: Flicker problem from HTPC via VGA to Panasonic PT-M1085
Hello All,
After having read some of the comments on this board, I'm certain that someone can help me with my new HTPC problem. By the way, I just joined this forum, so please forgive any protocol missteps.
For years I have fed various S-Video sources through a DVDO line doubler into my Panasonic PT-M1085 and have had no problems - loved the picture. The DVDO used a standard VGA out (the only option) which connected directly to the VGA port on the projector.
Last week, the DVDO died and I wasn't going back to 480 so I ordered parts and built an NVidia based HTPC. The video board is GeForce 7150/nForce630i and has full capability for custom resolutions. My connection to the projector is straight VGA with nothing else between the HTPC and projector.
Now the problem: I can setup a number of pictures, requiring full convergence etc. but after a few minutes the picture will start to flicker occasionally. Then after about 30 minutes to an hour the flicker will get so bad I can't watch at all and eventually I'll get the "no signal detected" message and I'm done. I'm not sure if this behavior is due to my cabling, but I assumed that VGA carried the sync signals properly since the DVDO line doubler had no problems. Or, is it due to timing and/or resolution?
Any help would be greatly appreciated!
Thanks in advance.
Scott
David_Web
Posted: Thu May 29, 2008 8:09 pm    Post subject:
The graphics card could be overheating. But that would usually show artifacts like snow or block in different color or black things jumping around etc.
digitalsdc
Posted: Fri May 30, 2008 5:23 pm    Post subject:
Thanks for your reply David. I had thought too about something overheating, otherwise why would the image be stable at first? However, I don't think it's the graphics card since it's a brand new machine and the graphics card is actually built into the motherboard.
Perhaps I'll try to run a fan directly into the projector and see if keeping it cooler might help.
Are there any other ideas?
