HOW-TO: Adding HDMI to CRT projectors
Posted: Mon May 26, 2008 2:54 pm    Post subject: HOW-TO: Adding HDMI to CRT projectors
There are many options available for getting an HDMI signal into older CRT projectors, TVs, or monitors that only have RGB, component, or DVI inputs.
Some options:
Moome EXT-FULLHD HDMI 1.3 to RGB converter
HDFury HDMI to RGB converter
Moome MUX-HD HDMI/DVI repeater
If your projector only has component inputs you'll need to use an extra box:
Box1020 RGB to Component Converter with Cable Driver, Gamma Boost, and Image Alignment Correction
TC1500 RGB to Component Converter with Cable Driver and "Left Shift" fix
Some TVs have problems using the HDfury converter as the TVs do not have any image adjustments. The boxes above solve all these problems allowing the HDfury to be used with any display. They also add extra 'nice to have' features such as gamma boost.
Like the previously mentioned boxes, the boxes below also mate very well with the HDfury for extra features and image quality:
Box1021 RGB Gamma Boost and Cable Driver
RTC2200 Component to RGB Converter with Cable Driver, Gamma Boost, and RGB passthrough
RTC2000 Component to RGB Converter with Cable Driver and RGB passthrough
See our products page for a complete list.
Questions? Post here or email the manufacturers (see the contact information on the order pages listed here).
