| Posted: Mon May 26, 2008 2:27 am Post subject: rejuvies and G-1 |
I'm trying to conduct some tests of the "Box 1020" but I need to calibrate the test projector first. My test projector has a problem with the red tubes G-2 so I borrowed Heywoods Sencore CR70 to test it and hopefully fix it.
I have to use the universal connector, which is just 5 clips that you connect to the pins on the neck. My question is about the G-1 connection. The instructions direct you to connect one of the clips to G-1. P19 tubes have G-1 on three pins. Does it make any difference which of the three you use. I show G-1 on pins 5, 11 and 12. Thanks,
_________________ Chip
Ile
| Posted: Mon May 26, 2008 7:24 am Post subject: Re: rejuvies and G-1 |
| stefuel wrote: | | Does it make any difference which of the three you use. I show G-1 on pins 5, 11 and 12. Thanks, | Those are all same, as you see when looking where pins goes to gun assembly.
