Nec XG-1350 System Board
Makieo
Posted: Mon May 19, 2008 4:53 pm    Post subject: Nec XG-1350 System Board
Has anyone found out what is actually going bad on the System Board which causes the scrambled mess. Ours does this every time the power has gone out. We will only be able to use high resolutions and the un-doubled signals. Then after a while of using the two or so signals the projector will recognize it will just start doing them all again.
Anyone know what is going bad on these boards?
Posted: Mon May 19, 2008 6:37 pm    Post subject:
The issue is currently being addressed. A fix may soon be available.
dropzone7
Posted: Mon May 19, 2008 7:05 pm    Post subject:
Good luck to you on that one. I still have this 110 here if you need a reasonably priced test chassis.
kschmit2
Posted: Mon May 19, 2008 8:29 pm    Post subject:
good things come to those who wait Smile
