09MEX3 tubes in a marquee??? Can it be done
Goto page 1, 2, 3  Next
voodoo7869
Posted: Mon May 19, 2008 5:48 am    Post subject: 09MEX3 tubes in a marquee??? Can it be done
I am looking to adapt a set of sony 1292 tubes to a marquee can it be done if so how?
this is for a project for a friend and any help would be appreciated.
Thanks John
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Posted: Mon May 19, 2008 6:32 am    Post subject:
Heres the pin-out for the 09MEX2 or P19LVB02 thanks to tse. Are you sure it is an 09MEX3 ?
http://f4.filecrunch.com/files/20080502/b54c29d9fa93ba1d32fe489c4eac45ca/CRT_base.pdf
voodoo7869
Posted: Mon May 19, 2008 6:46 am    Post subject:
i think so I will have to double check when i get home. so it is possiable then??? are there any special concerns that i should be aware of?
Ile
Posted: Mon May 19, 2008 7:23 am    Post subject:
All sony tubes have same pin out, that is totally different what Marquee tubes have. That is usually not big problem, but Sony tubes need extra focus voltage (about 15 kV) applied to pin 1. I believe that there is no easy way to get focus voltage to neck boards in Marquee.
Other way around this would be much easier.
voodoo7869
Posted: Mon May 19, 2008 7:29 am    Post subject:
gotchya I will have to let my buddy know that he would be better off selling the tubes for minty marquee tubes. especially since these are pretty minty. Thanks Guys
CRT_Ben
Posted: Mon May 19, 2008 3:34 pm    Post subject:
Ile,
So pin 1 (labeled "Arc Suppressor") in the .pdf diagram above takes an additional focus voltage? What would happen if you didn't supply that voltage?
Ben
papalek
Posted: Mon May 19, 2008 4:44 pm    Post subject:
I thought only the ES tubes had a focus voltage applied to them.
I do love my AmPro's
voodoo7869
Posted: Mon May 19, 2008 5:40 pm    Post subject:
I am not sure either way and i won't gamble either. mybe someone who has tried could anser TSE maybe might know
Ile
Posted: Mon May 19, 2008 5:49 pm    Post subject:
Ben
Yes that same pin. Newer tested without it, but I assume that tube won't work correctly.
Sony EM tubed Barcos, like 1200 and BG808s have this extra "focus voltage" applied to pin 1.
1292 probably have similar voltage connected.
Not sure if focus voltage is correct term, but least Barco use that term in SM when voltage leaves Quad. Then G2 board have focus/G2 block that divides dropped voltage to each neck board and to G2 board that use it for G2 voltages...
http://www.curtpalme.com/Barco808_Layout7.shtm
r.bauer
Posted: Mon May 19, 2008 8:09 pm    Post subject:
I have used sony tubes in a BG1200 without the additional (5kv?) wire connected for some time. Tube worked just fine.
I forgot to connect the wire while working on the projector.
tse
Posted: Tue May 20, 2008 12:50 am    Post subject:
The "arc suppressor" pin can be connected to ground. The Sony 09MI tubes in my 4200 have that pin grounded and its worked fine for many thousands of hours.
Scott
Thomas Jefferson
voodoo7869
Posted: Tue May 20, 2008 1:48 am    Post subject:
so would it be possiable to repin to work in a marquee? or is it just to much work. and for clarification it is a 09mfx not mex sorry about that
Ile
Posted: Tue May 20, 2008 12:41 pm    Post subject:
Rewiring neck boards takes about fife hours, if you have glue what you are doing.
You probably know that it's needed to remove LC hardware from both tubes and glue mfx3 to Marquee hardware. Other option is that you use 1292 tubes as is and build your own attachment system to Marquee. Both ways it's lot of work, I'd say least ten hours both ways.
There is also chance that mfx3 wont fit to Marquee LC hardware, because Sony tubes could have little different shaped face plate. MFX3 is also very long tube (15 mm longer than MI/MX), so there there is chance that it won't fit to Marquee tube housings. Also neck connector is 180 degree twisted, so does Marquee tube housings have room for twisted neck board, etc...
Marquee tubes will be available longer and tube type is more robust. Sony tubes have glued face plate that is weakness, also rebuild can't be done.
I have bare mfx3 here, so I can measure it if you still want to do this. Laughing
jantje112
Posted: Wed May 21, 2008 12:56 pm    Post subject:
I read a posting somewhere where someone had a mix from mec and sony in his 8500.
I shall take a look when I'm home
CRT_Ben
Posted: Wed May 21, 2008 1:33 pm    Post subject:
That would be me. (The mix was temporary, I'm running all sony-pinouts now)
My case is a bit different, though, because the tubes I had weren't Sony tubes, but rather oddball, P19LUG copies with a Sony pinout. So the tube internals were equivalent to P19LUGs, which is compatible with the Marquee. What I did have to do was extensive reworking of the neckboards to accommodate the Sony pinout. If you want, I can take pictures of what I did and post them up.
voodoo7869
Posted: Wed May 21, 2008 3:50 pm    Post subject:
could you please I would thinkg that the sony tubes would work I am just curious at this point
jantje112
Posted: Tue Jun 10, 2008 7:10 pm    Post subject:
Still curious if they fit. Let me know!
Ile
Posted: Wed Jun 11, 2008 9:04 pm    Post subject:
09mfx3 face plate is 184 mm x 145 mm. Tube length from face plate to end of neck connector is 437 mm. Bell length is 153 mm from face plate.
I have only 8" Marquee tube housing and ac hardware here, so I can't tell if it fit to 9".
CRT_Ben
Posted: Wed Jun 11, 2008 9:07 pm    Post subject:
Hey voodoo,
It might be a little bit before I have my PJ apart to take pics, but when I do, I'll post them up.
voodoo7869
Posted: Thu Jun 12, 2008 12:35 pm    Post subject:
great that would be wonderful take your time I am in no hurry
Page 1 of 3
