EXT Moone Box H Phase Problem
satguy2000
Posted: Sun May 11, 2008 7:03 am    Post subject: EXT Moone Box H Phase Problem
I have been having an ongoing problem on Barco 1208 with my new Moone EXT box (1st batch) as I have had to adjust the H-phase setting by over 17 clicks after replacing my older moone device and thus my Barco 1208 appears to be out of focus. Is this a normal adjustment between the two devices?
In theory, each input would require its own calibration, but if I were running the same source through it such as Dish HD or similar, would it not be at the same convergence point. When I installed the new device, the picture was extremely dark and off the screen to the left by about 10 inches. Only difference is that the setup no longer requires the Extron box as the new Moone Ext outputs negative sync.
Thank you for any of your thoughts.
