how much coolant do i need for a marquee 9500lc?
armstrr
Posted: Fri May 09, 2008 10:27 am    Post subject: how much coolant do i need for a marquee 9500lc?
i need to replace my cloudy glycol. mcm has 16 oz bottles. how many would i need to replace the glycol in a marquee 9500lc?
i assume this is the right stuff and the best place to purchase, correct?
thanks.
Electeohome marquee 9500lc, lumagen hdp, 9' da lite high power screen denon 2809ci paradigm speakers home made dual stacked subs
fireanimal
Posted: Fri May 09, 2008 10:37 am    Post subject:
Each tube uses around 20oz.
My Movie Collection
Heywood Jablome
Posted: Fri May 09, 2008 6:29 pm    Post subject:
MCM, sixteen ounces, about six bucks.
Posted: Fri May 09, 2008 7:33 pm    Post subject:
http://www.mcmelectronics.com/product.aspx?productid=20-4275
MSDS sheet....
http://www.mcmelectronics.com/content/ProductData/MSDS/20-4275.pdf
Heywood Jablome
Posted: Fri May 09, 2008 8:21 pm    Post subject:
That's the stuff. I had to google it... could not find it with MCMs' own search tool oddly enough.
armstrr
Posted: Sat May 10, 2008 3:45 am    Post subject:
ok, so 4 would do it with 4 oz to spare. should i expect some spillage and splurge for 5?
Posted: Sat May 10, 2008 4:42 am    Post subject:
Go for 5 just to be on the safe side. Wink
armstrr
Posted: Sun May 11, 2008 1:07 am    Post subject:
oh, forgot to ask. does anyone have a specific recommendation for the (black???) silicone to use when installing new bellows/changing glycol?
preferably quick drying. i am doing this at a friends place that is 1.5hrs away, so if faster drying stuff can save a trip...all the better!
thanks
Heywood Jablome
Posted: Sun May 11, 2008 12:17 pm    Post subject:
There is nothing that is quick drying enough... You should give the RTV days to set up, or the glycol will prevent its' curing and eventually leak.
armstrr
Posted: Thu May 15, 2008 10:15 pm    Post subject:
thanks HJ...will take that to heart.
unfortunately the coolant is on backorder for 2 weeks from MCM. any other sources for this stuff?
thanks
Posted: Thu May 15, 2008 11:51 pm    Post subject:
Here but more expensive ....
http://www.intertexelectronics.com/product13766.html
Posted: Fri May 16, 2008 12:18 am    Post subject:
Hello
The last tube I drained to measure the volume, 22 fluid ounces. Times three.
armstrr
Posted: Fri May 16, 2008 1:19 am    Post subject:
or how about here? http://www.tristatemodule.com/html/ptv_coolant.html
Thanks Tim...22oz it is
Posted: Fri May 16, 2008 4:27 am    Post subject:
Couldn't find the MSDS sheet is it mixed with glycerin ? Should be about 80% glycol and 20% glycerin.
