PJMoore
| Posted: Fri May 09, 2008 2:07 am Post subject: Marquee 8500 captive nuts |
Two of the captive "nuts" that keep the VIM attached to the chassis are missing. I cannibalized a couple of the little round captive "nuts" from an older chassis. Can anyone tell me a slick way to "attach" these captive nuts. They appear to have been press fit originally. I considered super glue, but am afraid it will make its way into the threads.
Patrick Moore
Joust
TV/Projector: Marquee 8501LC
| Posted: Fri May 09, 2008 3:09 am Post subject: |
you don't need them.
but you could press them in with vice grips or use 2 part epoxy.
| Posted: Sun May 11, 2008 4:34 pm Post subject: |
those 2 little round sheetmetal screw retainers are flared in like a pop rivot. Easiest thign to do is rob the entire moutning plate off an old broken 8000 VIM.
PJMoore
| Posted: Sun May 11, 2008 4:40 pm Post subject: |
I would agree dragan, if the problem was just that little plate betweenthe two VIMs, but mine are missing from the main chassis bulkhead. Bummer.
| Posted: Sun May 11, 2008 4:44 pm Post subject: |
Isn't Mike Parker a Marquee 8500 captive nut?
