Anyone in Michigan Detroit area with a G70 to check a board?
69shelby
Posted: Thu May 08, 2008 1:01 am    Post subject: Anyone in Michigan Detroit area with a G70 to check a board?
My Input board may be bad, anyone got one to test with or willing to try mine? Thanks.
AFryia
Posted: Thu May 08, 2008 1:39 am    Post subject:
I may be able to help My PJ is down at the moment.
Which board exactly?
PM me.
My Volt Blog
69shelby
Posted: Thu May 08, 2008 1:43 am    Post subject:
The input B board (the input board), see my other post, it was working fine then the picture went to all 'noise'. What wrong with your PJ?
AFryia
Posted: Thu May 08, 2008 1:48 am    Post subject:
Hopefully just the PA board.
My Volt Blog
Posted: Thu May 08, 2008 4:10 pm    Post subject:
I'll make this offer to both of you guys in case your interested. A workign G70 minus the covers, tubes {burnt} , and lenses to save weight. Then you can have the electronically complete, tested working chassis for $500. including delivery to you. you could swap your tubes/covers into it in about 2 hours or less.
Of course it would be cheaper to just repair whatever is wrong with yours but if you really plan to use a G70 a second machine acting as organ donor is pretty much a must-have IMO. These things aren't excatly know for the same kind of reliability as other CRT's.
69shelby
Posted: Thu May 08, 2008 11:53 pm    Post subject:
Thanks, I may take you up on the b board once I determine if that is the issue.
