What is port 3?
jkruger
Posted: Sun May 04, 2008 10:10 pm    Post subject: What is port 3?
What kind of input can be run into barco's port 3 on a 1209s? Is it rgbhv in a db-9 connector or can it accept component?
Posted: Mon May 05, 2008 1:15 am    Post subject:
As far as I know only RGBHV positive or negative sync.
jkruger
Posted: Mon May 05, 2008 1:34 am    Post subject:
So component only goes thru port 5? or does that make it port 4? Can I make a short adapter to run the hdfury into port 3 and open up port 4/5 to component?
jkruger
Posted: Mon May 05, 2008 1:28 pm    Post subject:
can I use port 3 for a connection to my pc with just a cable that is wired correctly?
and run whatever resolution the video card (nvidea 8600gt) is capable of?
How good will the cable have to be? I have about 20 ft between the pc and the pj.
Ile
Posted: Mon May 05, 2008 2:22 pm    Post subject:
http://www.curtpalme.com/Barco_Port3_Input.shtm
jkruger
Posted: Mon May 05, 2008 2:29 pm    Post subject:
Thanks! I don't know how I missed reading that before.
Posted: Mon May 05, 2008 4:11 pm    Post subject:
There are 650 pages on the main site. Not surprising. Wink
jkruger
Posted: Mon May 05, 2008 4:20 pm    Post subject:
How good is the cable going to need to be for a 20ft run and max resolution? I know it says high quality but is there a spec? Can I use a standard computer video cable or will it need extra shielding, etc?
Person99
Posted: Mon May 05, 2008 4:24 pm    Post subject:
1) The RTC2200 has noticeably superior component transcoding to what his built into your PJ. I and others have compared, the difference is not minor.
2) Don't use port 3, port 5 is way better on yours.
