| Posted: Fri May 02, 2008 10:17 am Post subject: RGB Bandwidth |
Two projectors both capable of the same resolution but one has a higher RGB bandwidth. Is there a visible difference in image quality?
KM
kschmit2
| Posted: Fri May 02, 2008 11:11 am Post subject: |
if the bandwidth difference is real and not just in the specs then the PJ with higher bandwidth should be better (all else being equal, i.e. same source, resolution, refresh rate, tubes)
Person99
| Posted: Fri May 02, 2008 1:43 pm Post subject: |
Higher bandwidth is always better (if true bandwidth as was said). If the difference in bandwidth is minor though, you may not notice the increase as other factors come into play also.
_________________ Dave
kal Forum Administrator
Person99
| Posted: Fri May 02, 2008 8:00 pm Post subject: |
| kal wrote: | If you feed both projectors a signal that is lower in bandwidth than the bandwidth of both machines then not so much, otherwise yes.
Kal |
Not true. Go find our (former) resident Physicists post on AVS. He covered bandwidth very well and showed how a theoretical display with infinite bandwidth perfectly renders white on black text, but as bandwidth is decreased to the point of just what is necessary, the image softens.
| Posted: Fri May 02, 2008 8:27 pm Post subject: |
Yeah, Dave, but Kal said if you feed both projectors a signal that is LOWER in bandwidth, then "not so much". As in, if the signal is below rated bandwidth, you probably won't be able to actually tell the difference. For instance, you might need to measuring equipment to tell the difference, or other factors will contributed more to any softening than bandwidth alone: lenses, setup, focus, wear, etc.
What happened to that guy, anyway? Chiem, was it? Did he just move on to other projects or did something happen to him? He was just going nuts with all things CRT - electronics, optics... then POOF! Gone.
Person99
| Posted: Fri May 02, 2008 8:32 pm Post subject: |
| ecrabb wrote: | | Yeah, Dave, but Kal said if you feed both projectors a signal that is LOWER in bandwidth, then "not so much". As in, if the signal is below rated bandwidth, you probably won't be able to actually tell the difference. |
You may not be able to notice (which is what I said in my first post in this thread) but the difference will be there. If you feed a 45 MHz signal to a PJ with 85 MHz bandwidth and one with 120 MHz, the 120 MHz one will resolve better. That is what Chiem explained (along with why this is true).
| ecrabb wrote: | | Chiem, was it? |
Yep, could not remember his name until you posted it!
| Posted: Sat May 03, 2008 3:19 am Post subject: |
Thanks for the responses. It seems that greater bandwidth is better in any circumstance from a technical perspective. I am really interested in real world performance i.e will you see the difference. In the computer world more bandwidth for say a network connection means more data transfer in any given time and this is noticable in real world terms. Anyway I intend to substitute parts in my PJ for increased bandwidth based on your responses.
secstate
| Posted: Sun May 04, 2008 6:43 pm Post subject: |
I have used both the 75 MHz Barco neckboards and 120 MHz Barco neckboards in my Barco Data 808s with P16 tubes and the difference was so small at 1080i and 720p, I could only tell near the screen with test patterns. At normal viewing distance and/or video I could see NO difference. The only difference I could see on video was the small amount of banding from bright objects on nearly black backgrounds that is common to the 75 MHz boards. I had a raster flickering problem with the 120 MHz neckboards so I went back to the 75 MHz and given the small difference in quality have not bothered to get to the bottom of the raster flickering (I think it might be related to the splitter).
| Posted: Sun May 04, 2008 6:57 pm Post subject: |
| Person99 wrote: | | ecrabb wrote: | | Yeah, Dave, but Kal said if you feed both projectors a signal that is LOWER in bandwidth, then "not so much". As in, if the signal is below rated bandwidth, you probably won't be able to actually tell the difference. |
Yep, could not remember his name until you posted it! |
Just like twisting speaker wire clockwise vs counter clockwise. We all know what's best and any fool and his illegitamate brother can hear the difference
_________________ Chip
jkruger
| Posted: Sun May 04, 2008 7:04 pm Post subject: |
Do they twist speaker wire the "other" way down under?
| Posted: Sun May 04, 2008 7:09 pm Post subject: |
| stefuel wrote: | | Person99 wrote: | | ecrabb wrote: | | Yeah, Dave, but Kal said if you feed both projectors a signal that is LOWER in bandwidth, then "not so much". As in, if the signal is below rated bandwidth, you probably won't be able to actually tell the difference. |
Just like twisting speaker wire clockwise vs counter clockwise. We all know what's best and any fool and his illegitamate brother can hear the difference  |
Here in West Korea we offer both services. Left twist for the left speaker, right twist for right speaker, double twist for the centre channel. Unless you are in other hemisphere then twist other way.
Gino
| Posted: Tue May 06, 2008 2:19 am Post subject: |
I agree with Dave, 'excess' bandwidth is a good thing. It plays into other factors, sharpness, background details, intrascene contrast and colours. If you only notice a small difference, it's because there are other factors which are weaker in your chain, ie. tubes, sources, lens, focus yokes etc...
deronmoped
| Posted: Tue May 06, 2008 6:52 am Post subject: |
Out of all the things I changed and messed with, it's the one thing that is out of our control that makes the biggest difference, the source material. I found this to be true back in the 70's with records, tapes and it's still the same now with DVD's and CD's.
Deron.
