Help needed with G70
mike calcott
Posted: Thu Apr 24, 2008 12:12 pm    Post subject: Help needed with G70
Surprised I have just received the G70, after checking for tube damage and condition I fired it up only to get a error 29 message this could have been caused with unseating the B board after the 3500 mile trip I will check tommorow in daylight. Other than reseating has anyone else experienced this error and whats the best remedy.
Old dog learning new tricks
Posted: Thu Apr 24, 2008 4:18 pm    Post subject:
Mike,
I didn't even know what the B board was - I had to look it up. It's because I don't have one! Curt's G70 layout says the B board is just the line doubler. You could always just pull it since you're probably not going to use it, anyway.
The G70 is pretty easy to tear into... I think before you even try to fire it up again, you should just pull and re-seat every board you can easily access. I did that after mine made it's long trip on a bouncy truck, and it fired right up.
Fujifrontier
Posted: Thu Apr 24, 2008 8:09 pm    Post subject:
send it to fuji for a look over, you can have a loaner 1020, just think Twisted Evil
mike calcott
Posted: Fri Apr 25, 2008 1:41 am    Post subject:
SC the B board is th RGBHV input board which has a daughter board attached for the component input. I am going to pull out today and check connections.
mike calcott
Posted: Fri Apr 25, 2008 2:53 am    Post subject:
I have just pulled all of the boards and re-seated and still no result. The projector goes for about 10 seconds the fans are all working, but then shuts down showing error 29
Posted: Fri Apr 25, 2008 3:04 am    Post subject:
That's a common failure. I've had about a 75% success rate in repairing them.. if someone hasn't butchered the board before I get it. They are complex boards, the last two I got in from the same guy were unrepairable. Let me know if you want to send it in.
mike calcott
Posted: Fri Apr 25, 2008 3:12 am    Post subject:
Whats the cost of a replacement board Curt?
Posted: Fri Apr 25, 2008 3:17 am    Post subject:
You don't want to know, ie new from Sony. I am out of spares as well right now.
. I can repair yours for $250 incl return shipping though.
mike calcott
Posted: Mon May 26, 2008 6:52 am    Post subject:
Just recieved my repaired B board, thanks Curt, all installed and firing on all 3 cylinders.
Thanks for your help Curt.
