RGBHV to RGB Connection
schneirc
Posted: Thu Apr 24, 2008 2:03 am    Post subject: RGBHV to RGB Connection
I have an Ampro 4600 with RGBHV connection.
I am purchasing a DLP small backup projector (Optoma HD73) for when it is out of service. Which is a lot lately ;(
Can I just hook the red, blue, and "T" connector the green and vertical sync cable to hook the existing cabling up to the new projector, because it has component?
Or will I have to hook it up another way? I really need to use the current cabling because it is run in the walls and ceiling. The projector also has DVI and HDMI, but I really don't want to spend another couple hundred bucks on my backup to hookup one of these way.
Thank for your help.
Bobby
Posted: Thu Apr 24, 2008 2:12 am    Post subject:
Even though the colors of the cables are the same, component is a totally different than RGB. To convert RGB to component, you need a device called a transcoder. See this page:
http://www.curtpalme.com/CRTPrimer_17.shtm
So, yes - you could use your cabling, but not without spending some money.
What's your source? Maybe your source would output component over the same cabling.
Posted: Thu Apr 24, 2008 2:16 am    Post subject:
You need a cable like the one above with BNC connectors on the end that will connect direct to the cable you use now (or five BNC male-male connectors)
Posted: Thu Apr 24, 2008 2:17 am    Post subject:
Ecrabb,
The projector can accept DVI-A throught the DVI port so all you need is a reverse RGBHV breakout cable a "RGBHV break-in cable" Wink
Posted: Thu Apr 24, 2008 2:21 am    Post subject:
Zebu Fellenz wrote:
Ecrabb,
LOL good one!
Say which site did you see that DVI-A to RGBHV cable at. I need half a dozen or so.
Posted: Thu Apr 24, 2008 3:02 am    Post subject:
AR,
I saw that cable on Ebay.
Posted: Thu Apr 24, 2008 3:38 am    Post subject:
Try: http://bluejeanscable.com/store/dvi-cables/index.htm
They make good quality cables and have DVI-A to 5 BNC cables.
