Will Stewart Model A work with Draper IR control?
250GTE
Posted: Fri Apr 18, 2008 4:11 pm    Post subject: Will Stewart Model A work with Draper IR control?
I was thinking of upgrading my Draper Premier with a larger Stewart Model A and wanted to know if anyone has had luck using a Draper IR box (i.e. the metal power box and the white IR receiver) with a Stewart Model A. I am not as worried with being about able to stop the screen midway down but want to find out if it will raise and lower the screen correctly. Also will there be any issues with adjusting how much black drop it has in the down position (I believe that this is set on the screen and not on the control box)? Any other issues I should think about?
Thanks in advance
Chris
