sony G70, spot burned tubes
Posted: Tue Apr 15, 2008 2:20 pm    Post subject: sony G70, spot burned tubes
Is anyone familiar with the spot burn phenomenon with G70's, like what the primary cause is or is there is more than one thing that can do it?
I need to know specifically if a failure of the GB power supply board could do this?
Posted: Tue Apr 15, 2008 4:08 pm    Post subject:
I wonder if its the same problem Mike Parker is seeing on the G90, look at his thread he mentioned soemthing about the dallas chip possibly causing it.
Posted: Wed Apr 16, 2008 12:19 am    Post subject:
thanks dude, I flipped through that thread and also Terry's on AVS. It seems to confirm my inclination to avoid the G series Sony's like the Bubonic Plague. Confused
Posted: Wed Apr 16, 2008 12:34 am    Post subject:
Thats why the Mighty Marquee will most likly be the last standing PJ !!!! Wink
Athanasios Hatzinerantzis
Posted: Wed Apr 16, 2008 12:40 am    Post subject:
I haven't seen this yet, but I'm guessing that it could be a Pa board problem as well.
Keep in mind that the spot burn on the G90 was caused by an end user that was uploading firmware or something like that. Not that it should have happened, but I think if I ever uploaded firmware to ANY set, I'd disable the HV or pull the CRT sockets to prevent damage to the tubes.
If draganm's spot burn was caused by a board failure, that's something different entirely.
