Runco DTV 1100
jkruger
Posted: Mon Apr 14, 2008 2:48 pm    Post subject: Runco DTV 1100
I have a chance to buy a runco 1100 with 4200 hrs on it. The seller says the red and blue are nearly tens and the green is an eight. I'm unfamiliar with the barco/runco models, what should I be looking for?
Posted: Mon Apr 14, 2008 3:01 pm    Post subject:
See here for a model cross reference: http://www.curtpalme.com/Runco_Model_CrossRef.shtm
It'll then point you in the right direction as to exactly what you're looking at....
Ksl
jkruger
Posted: Mon Apr 14, 2008 3:30 pm    Post subject:
The cross reference page says it has a "scanrate limited to that of the Barco Data 1209s" I didnt see a Barco Data 1209s listed. How much different is it than a BG? The seller said it only has RGBHV inputs.
Posted: Mon Apr 14, 2008 3:37 pm    Post subject:
I don't know what the scanrate of a BD1209s is as it doesn't really exist. Nobody gave me the actual scan rate to put in there so I had to use what I had.
The only diff is the scanrate limitation. Both are high enough to do 1080p/60.
It CAN'T only have RGBHV inputs. It'll also have port3, composite and S-video. The only input you should be using however is the RGBHV input.
jkruger
Posted: Mon Apr 14, 2008 3:45 pm    Post subject:
It sounded like he may not have known everything there is to know about it so I'm sure it has the other inputs also. I guess I would be using my hdfury for the input from my hdmi switcher.
Posted: Mon Apr 14, 2008 3:54 pm    Post subject:
Right into the RGBHV input (port 5). Sounds like a plan!
Posted: Mon Apr 14, 2008 7:06 pm    Post subject:
Dude, that thing blows chunks! And you should tell the seller so.
In fact give me the guys name address, and phone #, and i'll tell him for you! Mad
Thats just how great a guy i am! Thumbs Up
Embarassed
Chuchuf
Posted: Mon Apr 14, 2008 8:57 pm    Post subject:
Runco 1100 is a very nice 9" CRT based on the Data 1209S with Runco mods. Very sharp bright picture. Limited to 1920 x 1080P60. If higher scan rate is important you could "mod" the unit to do 72. It has LUG's for tubes and some pretty good late model lens's.
Terry
